Question about Craftsman Garden
Riding Mower Backfires
Backfiring back fires
  • 3 Answers
Suonds like you have a timeing problum could be cupple of thangs # 1 could be you have a bad keyway in your flywheel or your fly wheel is cracked that is what i would check
Posted on Mar 18, 2014
  • 126 Answers
SOURCE: mower backfires and loss of power
i would also check fuel flow. pull the gas line from the carb and see if gas flows out at a good rate (into a metal can of course) or if it trickles out. if the latter, then gas tank either has junk at the bottom preventing the gas from flowing or the vent hole (usually on the gas cap) is plugged.
i have also had my carb float bowl rust out on me, but that took 10 years.
Posted on Jan 29, 2009
SOURCE: gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Posted on Mar 24, 2009
  • 582 Answers
SOURCE: my riding mower backfires when i turn off the key.
before you turn off the key pull the throttle down to idle and wait a few seconds give the gas a chance to burn out of the cylinder
Posted on Aug 23, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
L2000 craftsman riding mower won't crank just backfires. Has new spark plug & carburetor fills up with fuel
Back fire is a result of timing being off. If the mower does not have electronic ignition, the points can be worn causing a timing issue. Back fire is usually and ignition of unburned fuel igniting outside the cylinder such as in the exhaust system. A valve not seating usually causes low compression but rarely does it cause a back fire. Start there.
Aug 20, 2017 | Craftsman Garden
2007 riding mower John Deere backfires while trying to start will not start
Inspect/replace the air filter to ensure proper air flow.
Inspect/replace the sparkplug(s) to ensure proper firing.
Check the position of the "choke" (if equipped; & by the way, most riding lawn mowers do not use a primer bulb button to prime the engine before starting).
Jul 03, 2015 | John Deere Garden
What causes backfire issues on a craftsman riding mower
The most common reasons any motor backfires are timing being out of adjustment or dirty spark plugs, in this case a dirty plug. Carbon deposits cling to the electrode, effectively changing the gap of the plug, or glowing long enough after the actual firing to cause another firing in between the normal firing, (back fire). I'd lean towards a good spark plug cleaning or just a new plug.
Aug 10, 2014 | Craftsman Garden
12 hp briggs backfires doesn't start
This could be a result of several different things, however the most common of these would be a sheered flywheel key. If this is the case it has throwed the motor out of time and is trying to fire while the exhaust valve is open causing the backfire and lack of compression to start. I hope this has helped.
Sep 30, 2013 | Simplicity "Citation 61"" 28-HP Briggs And...
My Sears Riding Mower Runs Rough & Backfires
don't know the model but check the valve adjustment
Apr 07, 2012 | Garden
Troy bilt riding lawn mower runs when its cold but backfires when it heats up
Sounds like you have a valve that is sticking open when it's hot. If your intake valve is not closing all the way when the engine fires, then it will "fire" back out thru the intake instead of the exhaust valve. You will probably need to have a professional look at it, as valves can be very tricky.
James
Nov 10, 2011 | Garden
Craftsman riding lawn mower tries to start and just putters then it backfires and shuts down.
it sounds like its the exhaust is blocked up or/and air filter, its the back fire that makes me think its a blocked exhaust,, iv had it before!
try taking it off and starting it up,,,,and yes its going to be noisy if it go's! untill you clean out the pipe, then put it back on again,
Nov 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
SAbre ridingb mower. Runs, backfires,almot die, still run. Backfire again,then dies and can not restart. PLEASE HELLP!!!!! PHIL Mpwer M#1438 Engime B&S M#287707 14.5hp, OHV
Sabre riding mower. Runs, back fires, almost dies,still runs. Back fires again, then dies and can not restart Please HELP!!!!!! Mower model #1438 14.5/38. Engine Briggs and Stratton, Model #287707, 14.5hp, OHV.
Jun 06, 2009 | 2003 Ford E150
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
