Question about Dometic Rooftop RV Air Conditioner
Water accumulating on kitchen ceiling around air conditioning vent
  • 35 Answers
Condensation
Posted on Mar 18, 2014
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Can i vent into kitchen ?
You can vent into the kitchen, but, the amount of moisture that will be present in the air will cause dew/sweat to build up on walls,windows,ceiling everything in the room,and I mean alot of moisture!!!
If you are asking if this will harm the dryer, the answer is no the dryer will be just fine.
Good Luck !
Apr 21, 2010 | LG DLE2050 Dryer
Unit releases xcessive amounts of water when
Part of an air conditioners job is to remove humidity from the air. The more humid it is, the moisture it will remove from the air. Some thru-the-wall/window air conditioners have fresh air vents. Ensure the fresh air vents are closed and make sure there is no air leakage around the unit & wall.
Keep your air filter and coils clean. If your unit has multiple blower speeds, use high speed during the more humid conditions.
I hope you find this information helpful moving forward. :-)
Apr 02, 2010 | Frigidaire FAC126P1 wall/window Air...
I'm getting condensation leakage from the vents in the roof. This is on a ducted system, and it's leaking from the two vents closest to the main blower unit up in the ceiling. It's very high humidity here...
Two things may need to be done here, one is to insulate the vents in the high humidity/temperature area to isolate them from these high conditions. The second would to install a drain pan under the system to catch any condensation and drain it away.
Mar 01, 2010 | Heating & Cooling
Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Jun 18, 2009 | Heating & Cooling
Water on the front driver side floorboard
It's not the air conditioning because the problem happened after a rainfall. The air conditioning would cause a wet rug while the air is on and it is very warm and humid outside. Then I could see a plugged drain causing the issue. It may be a leak around the windshield area or sunroof if you have one.
Start your car and put your fan on high. close the windows and doors. Spray a soap and water solution around the outside of the car starting around the windshield area. Look for bubbles forming. When you find the bubbles you found your leak.
Apr 10, 2017 | 2004 Toyota Corolla
My air conditioning vent downstairs is leaking water
it happens when aircondition is run for cooling and evaporator is frozen of ice. if you turn off aircon ice will defprost from evaporator.
May 31, 2009 | Heating & Cooling
Water is leaking from my downstairs air conditioning vent
I seriously doubt it's the AC. It may be the draing in the upstairs shower, If it's a water line it is a very small leak and is probably puddling in you ceiling. if not nbeing absorbed. Best thing is contact your homeowners insurance because you are going to not only have a plumber to deal with , but a mols issue as well. Sorry, good luck.
Water in the air vent
In a unrestricted rigid metal vent no water will accumulate. A dryer is exhausting hot and humid air to the outdoors. If the vent becomes restricted with a lint buildup, that lint can become wet. The more restricted the airflow is, the less airflow is available to remove the moisture. if there are low spots, or a flexible vent is used, pockets of moisture can accumulate......especially on a longer vent run.
Apr 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dometic Rooftop RV Air Conditioner Logo
29 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
