Question about Toshiba 55sl412u - 55"" class 1080p 120Hz LED TV"
Toshiba 55" LED HDTV 55SL412U 1080 p 120 hz led tv won't turn on with remote or at sensor
I can hear a click when I press the power button on the remote several times, but then nothing happens; the tv doesn't turn on.
    Top Expert:
  • Toshiba Master
  • 34,814 Answers
Probable power supply failure
Posted on Mar 18, 2014
SOURCE: Toshiba 42HPX95 wont turn on
I am having the exact same problem with my Toshiba 42HP95. From the information that I have been able to glean from the internet, it looks to be some sort of problem with the power supply or some other component of the power circuit. I am giving up and getting service
Posted on Jan 16, 2008
tvservice306
  • 458 Answers
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Posted on Oct 02, 2009
  • 18 Answers
SOURCE: I want to set the remote to change volume on TV
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Posted on Oct 18, 2009
jerryg50
  • 1667 Answers
SOURCE: Toshiba 42hp66 has sound but no picture
Part of the power supply is in protect mode. There is most likely a short or something failed on one or more of the boards.
The service rep would swap out boards to locate the fault. Then he would leave the new board(s) in the set, and perform any necessary adjustments.
Take the set in for an estimate before approving repairs. There are many times these sets are not worth serving when they are out of warranty.
Jerry G.
Posted on Mar 05, 2010
welcomejee
  • 10594 Answers
SOURCE: Toshiba Regza 42RV535U 42 in.
TV needs back light inverter board replacement as discussed in chat session, required board is available with shopjimmy.com
Thanks.
Posted on Jan 25, 2011
I'm trouble shooting my Vizio e550i-2b It has power no backlights, image can be seen with a flashlight, I've replaced led driver board and problem persists, do you suggest main board next?
If you can see an image with a flashlight and you can control the tv with the remote then the main board is not the problem. You've replaced the LED driver board, so that leaves the LED strips inside the LCD panel as the likely problem.
Feb 11, 2017 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
How do i turn it on without the remote ?
There is small switch on the lower left of the side Panel.
POWER - Press and hold to turn TV off or on.
INPUT - Press to change input source
Mar 23, 2016 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
TV won't turn on?
LEDs are notorious about overheating and ruining the thermal capacitor... it round and is soldered onto the main circuit board. Easy to replace yourself..just obtain the correct part and go easy on the solder using a 25 watt soldering iron... don't use a high powered solder gun of it's toast!
Jun 16, 2015 | Toshiba 55SL417U 55"" 1080p LED-LCD TV -...
How to shut off manually
UN55D6400UF TV Will Not Power Off If your TV is on but will not power off when you press the power button, you could be having an issue with your remote control or a faulty circuit inside your TV.
To determine the source of your problem, follow these steps:
  1. Power the TV on if it is off.
  2. Unplug the TV from the wall outlet for 30 seconds, and then plug the TV back in.
  3. namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=yokn68wxkhym@namo.co.kr&sep=%7c
    1. Press the POWER button on the remote control.
    2. [img src="http://support-us.samsung.com/cyber/namo/namo_fileview.jsp?type=nfs&pid=decisiontree&did=57355&cid=79HKC8BOY9YC@namo.co.kr&sep=%7C" height="51" border="0" width="50">
      • If the TV powers off when you press the POWER button on the remote control turn the TV back on continue to Step 4.
      • If the TV does not powers off then there is a problem with the remote control. Click here to go to the Remote Control troubleshooting section of this guide.
    1. Press the POWER button on the TV.
      • If the TV powers off with the remote but does not power off with the power button on the TV there could be an issue with the touch sensor on the TV. Before setting your unit up for service try these two things.
        1. Try sliding your finger accross the power button.
        2. Have other people try using the touch buttons on the TV.
        3. If either of these two options work then there is not an issue with the touch sensor on the TV. There are many variable that can limit the conductivity of a persons fingers. The conductivity of your fingers might not be enough to easily control the touch sensor on the TV.
        4. If the TV does not power off when you press either the POWER button on the TV or on the remote control, then the TV will need to be serviced. Click the Create online service request button below to have the TV repaired.
Mar 26, 2014 | Samsung UN55D6400 - 55" 1080p 3D LED LCD...
I need remote codes for a src-300a to a toshiba tv
One of these three codes should work: 0156, 0060, 0154
In addition, here are the commands to get your remote into programming mode should you require them.
  • Press the LED button and hold it down until the LED Flashes.
  • Press the REC button. The LED stops blinking at this point and stays solid.
  • Press and release the POWER. The remote is now in TV Code Scan Programming Mode.
  • Press the UP ARROW (above SELECT) button to scan through all the TV codes. When you reach the correct TV code, the TV will automatically turn off.
  • Press the SELECT button to store the TV code. The LED flashes rapidly then stops, indicating code has been stored.
Dec 26, 2011 | Motorola Televison & Video
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
Toshiba 55sl412u - 55"" class 1080p 120Hz LED TV" Logo
167 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
