Question about Febi 2009 - 2009 Audi A4 Quattro Engine Coolant Temperature Sensor O-Ring
I have a 2009 audi a4 quatro. My check engine light keeps coming on. I've replace the catylictic converter, 02 sensor, and put spark plugs in it, light still comes on
The car drives fine to me, but the check engine light just keep coming on I've replaced the catalytic converter, 02 sensor, and new spark plugs
    Master:
  • 966 Answers
Richard, did you do what you did based on diagnosis?
Try your fuel tank cap. Make sure it is closed securely.
Posted on Mar 19, 2014
    New Friend:
    Problem Solver:
  • 6 Answers
The check engine light indicates that your engine computer has something it wants to tell you. Usually, what it wants to tell you is that a sensor reading is out of range, and there are a lot of sensors beyond just the oxygen sensor. When the check engine light comes on, you should get the codes "scanned" to get the details. I recommend you take it to a local auto parts store that does free code scanning. In my region, Advance Auto Parts provides this service. You could take it to your dealer, but they're going to severely overcharge for the code scan and probably try to scare you into letting them fix it.
A code scan will tell you exactly why the computer thinks something is wrong and will do a great deal to help you locate the real problem.
Posted on Mar 18, 2014
2001 audi a4 quatro 2.8l DOHC check engine light is flashing and my scanner gave the fault code p0305 and a pending code p1340 . What should I do tofix the problem?
p 0305 is misfire on no 5 cylinder code p1340 refers to camshaft (CMP) sensor 1 bank/ crankshaft position (CKP) sensor ---out of sequence === causes ---valve timing--CMP/CKP sensor installation---CKP sensor rotor
misfires are more injector problems that plugs
take it to an authorized service center for the position senor and valve timing problems
Dec 12, 2016 | Audi Cars & Trucks
Audi a4 1,8 s line
The computr needs a flash or reprograming w a factory scanner. It common not to recognize new motor. First make sure pins are clean on computr plug
Feb 06, 2016 | 2002 Audi A4
My 2002 audi a4 quatro torque converter light comes on and off (mostly on) but shifts fine
Check for fault code. Check fluid level . Check sensor for correct operation or loose connector
Feb 15, 2013 | Cars & Trucks
Check engine light came on recently. Car then
The exhaust system has two 02 sensors One before the cat converter and one after. The #2 02 behind the cat converter is the one that trips the light if emmisions are unacceptable coming out of the converter. The #1 or front 02 sensor monitors and constantly adjusts the fuel to stay within parameters. If the #2 tries to compensate for an inefficient converter and it conflicts with the #1 02, the ebgine will run poorly due to either too rich or too lean fuel adjustment. Have the #2 02 sensor replaced and the converter checked. Good luck
Nov 15, 2009 | 2005 Toyota Corolla
1998 audi a4 quatro - where is the coolant part in
CTS is at the back of the engine, behind and below the passenger side cylinder head, beneath the intake pipe going from the mass airflow sensor to the throttle body. It's either black or blue in your car, has four wires coming off the connector plugged into the top of it, and has a retaining clip that holds it as well. Get a new clip when you buy the sensor - they're plastic and break easily.
Sep 26, 2009 | 1998 Audi A4
2002 AUDI A4 OIL LIGHT COMES ON AND CHECK ENGINE LIGHT.
The code system too lean, is caused by the bank 1 02 sensor, as far as the oil light coming on with oil ok,I would say the oil sending unit. Have those checked or replaced. Without testing this and that, it's hard to say what's causing it.
Jan 27, 2009 | 2002 Audi A4
Oil for 2007 AUDI A4 2.0t Quatro
The best balance of price, quality, availability that I have found is Mobil1 synthetic - it's on Audi's approved oils list. With the 2.0T engine, you absolutely want to use synthetic (the Audi turbo fours are known for oil sludge issues), and you want to do a SeaFoam treatment every 15k miles or so - that combination will keep your engine in great running shape.
Aug 14, 2008 | 2007 Audi A4 Convertible
Fault code 0562.oil level sensor light on dash display.sensor replaced dash still displaying oil level
I also have a 2004 Audi A4 3.0 Quatro and the low oil sensor comes on periodically. I pull the oil dip stick and put it back and it goes away. Maybe it will work itself out.
Aug 05, 2008 | 2004 Audi A4
Febi 2009 - 2009 Audi A4 Quattro Engine Coolant Temperature Sensor O-Ring Logo
Top Febi GPS Experts
Will Halftowaite
Are you a Febi GPS Expert? Answer questions, earn points and help others
