Question about Toshiba 22LV505 22 in. LCD TV
No picture when connected to computer - Toshiba 22LV505 22 in. LCD TV
Download pictures from camera to pc
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 09, 2012 | Canon Cameras
Kodak easyshare c743 won't connect to computer to transfer pictures
May 25, 2012 | Kodak EasyShare Cameras
I cannot tranfer pictures from sony dsc-w30 camera to my computer .camera screen always show usb mode connecting
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Apr 17, 2012 | Kodak EasyShare SV811 (8858946) Digital...
I use pl70. i am having problem downloading my pictures. when i connect my camera to my computer i do not see my pictures, i have even tried inserting the memory card directly to my computer and i still...
1) Using new memory card. first connecting memory card to computer and format. and insert memory card to camera. making single shot. then connecting computer you see picture.
Memory card formating in camera may be not working computer or other device.
Mar 29, 2011 | Samsung PL 70 SL720 Digital Camera
As I connect the camera to the computer, the recent pictures I to
Nothing is wrong. The file names of the recent pictures probably duplicate those of your old pictures. Your computer is probably caching the images associated with those names until you double-click on them.
Since you declined to specify the type of computer and the software you're using, I'm afraid I can't tell you how to clear the cache. I also assume you're not really connecting your 35mm SLR camera to your computer.
May 15, 2010 | Photography
Cannot load pictures onto SmartParts Digital frame
You can't see pictures on the frame while it's connected to the computer. The frame is supposed to say, "PC Connection established..." If you go to My computer and look for your frame as a removable device, you can open it and view the internal memory of the frame. You can see all the pictures on the frame and delete them if you wish.
Apr 25, 2009 | SmartParts (1DPFSP01) Digital Picture...
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  4. In the menu bar, select File ® Copy to.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Toshiba 22LV505 22 in. LCD TV Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
