Question about Brother PE770 Computerized Sewing Machine
Machine keeps powering off, and then right back on.
Keeps shutting off and then right back on, and I have to start design all over. Any ideas?
Update the software
Posted on Mar 18, 2014
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
My Viking Designer 2 keeps telling me it is set for pressure foot Q, I don't even have that foot. I can't use any of the decorative designs I have been using. I have no idea what I did to chan
if you have not found a solution yet, normally turning the sewing
machine off and back on again usually clears the computer part
of the sewing machine.
but if it doesn't then a trip to the repair shop may be in order
to see if there is something wrong with the motherboard
Nov 04, 2012 | Sewing Machines
My brother 270D keeps shutting off
Take your machine back to the other side of the house. See if it works better there. If it does have an electrician come out and check the new location's power. There may be a problem in the houses wiring.
Sep 07, 2012 | Brother SE-270D Computerized Sewing...
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
Husquvana 5610 keeps running when power turned on
Probably has a bad filter capacitor in the connector for the foot control in the back of the machine. If you check with a knowledgeable repair center, they should know of this problem. If they don't have a clue what may be the cause, find someone that knows. Any knowledgeable technician will know of the capacitor that makes the machine run.
Oct 01, 2011 | Husqvarna Designer I
My machine's screen keeps turning off but the function buttons stay lit. The machine appears to reset itself randomly while im sewing and sometimes even when im not near it. Everything else seems to be...
Has your Designer 1 ever had the power supply replaced? Almost all Des 1's had a recall that was replacement of the power supply. Any Husqvarna Viking dealer will be able to check the power supply, or transformer, in your machine and make sure that it has been replaced. Sometimes this can be a loose connection inside the power supply.
Sep 17, 2011 | Husqvarna Designer I
EMBROIDERY STOPS IN MIDDLE OF DESIGN. PRESS RUN AND IT WILL RUN FOR A SECOND AND STOP AGAIN
Are you sure you are not "double-pressing" the Start/Stop button? The machine might think you have said Go and Stop straight after? Try embroiderying using the foot pedal - see if that works for you. I guess you are aware that the machine will stop for thread colour changes. Do an experiment on any old piece of fabric - load the design and press the Stop button (not the one mentioned above, but the one of the left-hand side above Fix). The light should go out. This will eliminate the colour changes - the design will sew out in one single colour only. See if it keeps running and completes the design.
I would also "park" the embroidery arm, turn off the machine, remove the arm, replace the arm, turn machine back on and try again. Sometimes it just needs to start all over to get things back on track.
Jun 14, 2010 | Husqvarna Designer I
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
May 29, 2010 | Husqvarna Sewing Machines
Disk error
It is just one design of a menu full of designs, is that right? Try re-loading the design from your software and maybe a re-format of the floppy before writing to disk.
Apr 26, 2009 | Husqvarna Designer I
Brother PE770 Computerized Sewing Machine Logo
52 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
