Question about Fisher Paykel EcoSmart GWL15
My kenmore elite dryer will not stay on when i take my finger off the button and if i hold it down it doesnt heat up
  • 35 Answers
Check the sensors located near igniter inside dryer
Posted on Mar 18, 2014
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Kenmore Dryers
I have a kenmore elite quit pac 2 that wont stay running unless you hold the start button down. I dont have much money to fix it but cant afford to buy a new one. What can I do?
  • firstly dont hold your finger on the button
  • by doing this you are running the motor on the start winding
  • this winding is for momentary operation only, just to get things started.
  • You must have a fault in the run circuit of the motor.
  • To save your dryer. dont use it till you get someone who can fix the run circuit. It may only be contact failure, or jammed up with lint.
  • Good luck
Jan 23, 2011 | Dryers
My kenmore elite dryer wont stay running after you push the push to start button. it starts runs only if you hold the button down. which i did for a shot period of time and also notice no heat starting...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 16, 2011 | Kenmore 63942 Dryer
Kenmore Elite electric dryer, no heat, runs if holding start ****
with this combination of problems it sounds like a power problem on the control board being you have more than one problem,it sounds as though you arn't getting a latch voltage at the relay energizing coils that latch the relays to power the motor and element
Apr 16, 2010 | Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer will not stay on.
sound like you have a whirlpool or kenmore dryer and if so you have a bad microcomputer and if it is one on those then send me the model and serial number from inside the door on the sticker and i will see which part you need and if i may have one myself to help you out / larry
Nov 28, 2008 | Kenmore Dryers
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Fisher Paykel EcoSmart GWL15 Logo
18 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
