Question about Maytag Atlantis MAV6000 Top Load Washer
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Posted on Jun 14, 2009
Waht causes black flakes on clothes when washing?
Hi, it sounds like you have to buy one of the inside washing machine cleaners its a liquid that you put in the washer and let it run its cycle to flush clean the interior of the unit.
Jan 23, 2016 | Samsung 4.8 Cu. Ft. 13-cycle...
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
Oct 15, 2017 | Maytag Neptune Washing Machines
Motor arcing and smell of burning
you have a major electrical problem, unplug tool and remove the brushes to check their condition. Rotate the blade by hand and look for any unusual wear pattern or discoloration. This would indicate a failure and the appropriate parts would need to be replaced.
Jun 06, 2011 | Makita Circular Saw - 15 Amp, 7 1/4in....
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
7 1/4 B&D saw - blade stalls but motor continues to run
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Jul 28, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
No inner washer to keep blade in place
I really wish I could give you a link to somewhere you could find your part but I have checked all the ones I know and it's a pretty big list. I came up empty. I just don't see a way for you to get a replacement for that saw.
However many saws have the same or similar parts. You need to measure the shaft diameter and head to a hardware to check what ever saw you can for a replacement.
Worst case scenario is to take your saw to a small local machine shop. Find the oldest guy in the place and explain your problem. Buy him a cup of coffee and he'll make you one for practically nothing.
Hey it worked on my boss every time.
I hope this helps.
Nov 29, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Craftsman # 315,10851 7 1/4 inch circular saw.
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Sep 12, 2009 | Saws
Washer wont spin
the the motor coupling ..unit want wash or spin,,,if you would lik to try your hand at replacing it lety me know,,onthejob
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Flakes of dirt on washing
Is this perhaps a second hand machine or it has possibily been stored away for some time? When a washer dries out inside ( behind the washer bowl ) and is then put back in service, dirt from years of use caked on insides flakes away ( like a dry leaf crumbles) and re-enters the wash and can end up on washed clothing. The only way to stop this is complete removal of washer bowl , scrub and clean insides to remove caked on dirt - reassembly. problem fixed !
Jul 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Hoover Premier 706
I have the same washer and the paint started to flake from the bottom of the bowl. Rust under the baked enamel made it lift. I peeled the loose paint then applied rust converter and a zinc paint. This patch is still ok after 12 months but my wife is complaining about paint flakes and rust on some clothes. In my opinion, the only way to remove the agitator is to undo the nuts retaining the shaft from the inside. I guess I will find patches of rust under the agitator and depending on how big and deep they are will determine if I replace the machine or patch the rust.
Bob
Sep 03, 2006 | Hoover HTC243 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
146 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
