How many 3-digit number combinations can you make with using odd numbers
How many 3 digit combinations can you make with odd numbers repeating
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
If the numbers repeat twice, there are five combinations (111, 333, 555, 777, and 999). If the numbers only repeat once, there are sixty combinations (113, 131, 311, 115, 151, 511, etc).
Posted on Mar 18, 2014
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
How many combinations are there for the numbers 1, 2, 3
If you're asking for three-digit combinations, 27.
May 06, 2014 | Computers & Internet
I have 6 digits, numbers 1-6 need to list all combinations possable
There's only one six-digit combination possible, namely the digits 1, 2, 3, 4, 5, and 6.
If the order matters then there are 720 possible permutation. I'm not going to list them all. Start with 123456, then 123465, 123546, and so on to 654312 and 654321.
Mar 25, 2014 | Computers & Internet
Combination calculator
how do i find out the possible number combinations for the numbers 1238 but 1 and 2 repeat making the numbers become 112338 how can i get a list to print off all the possible combinations
Jan 01, 2014 | Office Equipment & Supplies
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
hope this helps
Oct 17, 2012 | Apple iPod nano 4th Generation
Using all digits 5, 4 and 8, how many different numbers can you form if no digit is repeated? What if digits may be repeated?
This question refers to combination and permutation. In order to calculate this, you need to think of it logically.
To calculate without repeats, it's fairly simple. In the first digit x, you have three options (5,4,8), however in y there are only two options (the two which were not in x), and z only has one option (the one that was left over). When you calculate them out you do it by multiplication, IE 3*2*1=6. This is also called a factorial, and is expressed as 3!
To express with repeats, the formula is a little different. It depends on what size number you are trying to make, and I'm not sure that you gave that information. If you are only making a 3 digit number, the solution would be as follows. x has 3 options again, but since there can be repeats both y and z have 3 options as well. When calculated, it comes out to 3*3*3-27
Jul 19, 2011 | Computers & Internet
This mystery number has 4 digits.every digit is an odd number.none of the digits is a 9.every digit in the number is different.the smallest is in the tens place.the preceding describes two possible...
Odd numbers 1, 3, 5, 7
Uses all 4
1 is in the 10's place
7513 is the largest number that can be created
This is answer based on the provided information.
Jun 16, 2011 | Casio Office Equipment & Supplies
Form the greatest 5 digit number that rounds to 15000 using only odd numbers from 1 - 9 and without repeating a digit
Round to how many significant figures? And what does this have to do with Kodak digital cameras?
(15397)
Jul 08, 2010 | Kodak Cameras
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
