Question about Sebo X4 Bagged Upright Vacuum
Sebo upright foot peddle came off how do I attach it back
Yes but you will need a new spring to put on it or you can leave it off it will not harm anything it just will stop the vacuum from standing on its own so yes
Posted on Mar 21, 2014
3 Suggested Answers
  • 389 Answers
SOURCE: how do I fit the foot pedal back on on a SEBO
This is much easier to do than to describe! Your question suggests that you plan to re-fit the same pedal that has come off, so first you need to be sure that nothing actually broke when it came off. You should be able to clip the plastic part back on to the metal part - it should stay there and not fall off (if it falls off, you need a new one). The trick is to get the flat metal part correctly located in the plastic part, so with the plastic part not clipped on, pull the metal part down and rest it in the plastic part, then push the plastic part in to position. The flat metal part should then be trapped behind two projections on the plastic part, so that there is some movement, but not much. These projections may possibly have worn away, allowing the pedal to come away in the first place, in which case you will need a new piece.
I hope this helps. If so, please remember to rate this response as I value feedback. If you need more help, just post a reply here and I'll get back to you as soon as I can. Good luck!
Posted on Mar 15, 2010
  • 389 Answers
SOURCE: I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
Posted on Feb 15, 2009
The pedal on my hoover is stuck
Your foot pedal is likely not snapped on to the axle assembly all of the way.
Oct 16, 2014 | Sebo X4 Extra Bagged Upright Vacuum
A picture of how to replace foot pedal
This is what your foot pedal should look like installed 25164187-2lznyozag1oxf2xdn4xr045t-3-0.jpg
Sep 30, 2014 | Sebo X4 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
I need a new set of instructions for my sebo x4 extra upright cleaner
you will have to call sebo or the dealer you brought it from to get manual
Aug 27, 2010 | Sebo X4 Extra Bagged Upright Vacuum
How to clean sebo rug brush
there's a button lock on the top of the nozzle and the bottom of the vacuum where they meet. That should release the carpet nozzle from the vacuum cleaner easily.. you may have to jiggle it to get it loose, but there's a button lock mechanism that holds it in place
Apr 13, 2010 | Sebo 9803AM Upright Vacuum
I have many SEBO automatic X4 vacuums with broken foot pedals. I would like to buy 5 foot pedals that I believe the part number is 5059DG can you tell me where to get it
I guess that depends where you live... plenty of spares sources online (google sebo vacuum spares)... otherwise google sebo dealerships in your country/locality.
Feb 19, 2010 | Sebo X4 Bagged Upright Vacuum
I have a Sebo x1. It will not pick up from the head.
Hi
If the wheel isn't moving when the upright handle is swung down normally then the hydrallic action will be broken. The wheel only adjusts to the carpet when the handle is swung down and the wheel goes to the highest position. HOWEVER if you have large pile / thick carpeting then the X1 will struggle to pick this up as it doesn't cope well with thick carpeting. Sebo's G1 series with a manual adjuster dial is better in that respect. Put back the wheel as normal and check that it is lowering once the handle is unlocked. If it doesn't show up with the lights on the front of the hood showing that the wheel is going down, then its either the carpet thickness or the hydrallic wheel mechanism is broken. Contact Sebo in your country and they can usually send out a line diagram or suggest a repair.
Jan 30, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
The Clog light is on my Sebo Essential G1 vacuum
If you are sure the base is clear, and that the flexible hose and attachment tube are clear, the only other common place for a blockage is the swivel neck that joins the base to the bottom of the dust bag housing.  Here's what to do:
Press the housing release button (front bottom of bag housing) and lift off the bag housing from the base. This can be quite hard (three or four hands would be helpful) but be sure to lift straight. When you've got the bag housing off, release the foot pedal and lower the swivel neck to 45 degrees.  Check inside the swivel neck channel closest to the foot pedal, and clean it out as necessary.
If this doesn't work, please post again and I'll see what else I can do...  If it does help, please rate me!
Nov 27, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
156 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
