Question about ASUS LCD Monitor
My monitor displays bright green pixcells in the black areas of text and pictures .I have tried a different monitor (lcd also, no problem ) to isolate the fault back to the monitor.
    Sergeant:
  • 361 Answers
Some time we can see that of problem as screen convert in to voilat and green colour. it is called colour fade. assambaling parts is lose of bord and other. it can be correct by soilding by expert tech. it is more seen in old crt monitor. thanks
Posted on Jun 14, 2009
2/3 of display is black
Strange could be video card issue or broken screen. try connecting it to TV or another monitor see if the picture is clear than video card is fine and display is damaged
Mar 02, 2011 | HP Mini 1000 Netbook
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    I have a Philips 170S4. On startup it displays the memory check fine. Then everything goes black, the green light indicating the monitor is still on is still lit up. I can only JUST see some pictures on...
    did you adjust the brightness, also in windows settings?
    pls check with another monitor ,also you can check monitor with another pc or laptop
    try with reset the monitor settings
    also change the resolution and display frequency
    Oct 03, 2017 | Gateway FPD2275W LCD Monitor
    Dell screen goes black , after 2 seconds but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time ,
    but when low down the brightness it work good it not goes off , but it is very low brightness and difficult to read text some time......WHAT?
    Can you explain in a bit more detail please...I don't know what you mean by.........
    'when low down the brightness it work good'?
    But try holding down the FN key on your keyboard & tapping the 5fc1ca0.png Button that alters the brightness.
    Sep 04, 2009 | Dell InspironTM 1501 Notebook
    LCD Dell Monitor displaying purple and green rather then picture.
    sounds like your monitor is starting to go out. if there are any speakers near your monitor, it is likely magnetic interference. try moving your monitor to a different area and see if it still does this. if it does, i would replace the monitor. if it doesn't, just simply reorganize the area around your monitor and it should go away after degaussing the screen.
    Jul 11, 2009 | Dell E177FP LCD Monitor
    Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
    You might find a BACKLIGHT FLUORESCENT BULB on eBay.
    Jul 04, 2009 | Dell E173FP 17" LCD Monitor
    Black/Green Distortion - Picture Quality - Wharfedale
    This is no solution but a point in a probable direction.
    A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
    Mar 11, 2008 | Televison & Video
    Color in text
    The monitor convergance adjustment is out . Is it a LCD or CRT
    Jan 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
    Spots on my display
    There's nothing wrong with your camcorder. Cystal-shaped spots, black spots, and bright spots of light (red, green, or blue) can appear on the LCD monitor for a variety of reasons. These spots are not being recorded on your tape. But if these are distracting your videotaping, consider taking a slightly different shooting angle and the spots should go away.
    Sep 06, 2005 | RCA CC-432 Camcorder
    ASUS LCD Monitor Logo
    213 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
