Question about ViewSonic PJ458D DLP Projector Multimedia Projector
How much doe s the lamp cost? I never used it that much.
WHAT DOES A COOLANT SENSOR LIGHT COST?
98 olds?
a bad lamp is a dead lamp , not stuck on.
so your input is false.
no the lamp does nothing at all but REPORT over heated.
please say the exact name of lamp, on the cluster.
and ask why it is stuck on.
the operators guide, says what, get it serviced.
diy persons, know it either telling the truth or fibbing
we use a meter to check engine heat if it is ok the lamp fibbing
the lamp fibs when the overheat sensor is bad
or the wire to it falls off and hits the body metal.
Jun 12, 2014 | 1998 Oldsmobile Intrigue
There is red and blue lines around screen and images. (Almost looks like it should be 3d). Does this mean it needs a new lamp/bulb? It is only 6 years old. What is the cost for the part? Thank you
If model number is as listed (46f500) it does not use a lamp or bulb but has three picture tubes.
3d means the two convergence chips in the set have failed.
It depends on if you can solder etc, not a very expensive parts cost (under 30 dollars)
Can you solder?
SD TECH
Sep 17, 2011 | Hitachi 46F500 46" Rear Projection...
Tv wont come on lamp and temperture light comes on how much does the lamp cost and is it cheaper to hv it professionally done
The lamp of quality cost about $150-$200. Check how much the service call will be. If too expensive, install it yourself
Jun 11, 2011 | Hitachi UltraVision 60VF820 TV
Hi, i have a ultravision digital hitachi 50v500 , theirs a light bulb in the tv that needs to be replaced. how much would that cost to fix it?
Replacement lamps with housing will cost between $175-200 at a retail store, this does not include installation. You can buy a lamp without the housing for near $75-100 but this requires you to remove the old lamp from the housing and installing the new lamp into the old housing, which can be tedious and potentially damaging if you do it incorrectly. BUY THE LAMP WITH THE HOUSING it will save you time and frustration.
Mar 03, 2011 | Televison & Video
My projector does not show any picture,only show blue screen, does the lamp need replacement an if it does how it will cost
If you are seeing the blue screen at startup, then the issue is more than likely not the lamp. What is your input source and what inputs are you connecting to?
If you are using a laptop PC, note that the VGA output by default is not active. You have to go into display settings and change it to dual monitor for VGA output to work.
Oct 05, 2010 | Hitachi CPS210LAMP Projector Lamp
How much does a xl 2400 lamp cost
XL-2400 lamp would cost you $200
Available in Sony Accessories Store under part number
F93087500 LAMP BLOCK ASSY XL-2400
Jun 09, 2010 | Sony (XL-2400) Projector Lamp for...
My z62dc1d dlp tv is showing a dark picture
www.encompassparts.com sign in as guest. put 31419SN984A into the part number search. you will get a part no longer available, use substitute part.
Mar 15, 2009 | Zenith Z62DC1D Television
Projection TV - Red Lamp not on
You can get a replacement Red CRT at the following link its used in good working order for 135.00 with free shipping compared to about 375.00 for new if available. The site also provides free step by step instructions on how to do the installation.
here is the link http://servicemanuals.vstore.ca/
Apr 04, 2008 | Televison & Video
14 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
