Question about Sanyo DP42746 42 in. Plasma Television
We're is the reset button on Sanyo model number DP42746
T.V. Just goes black for no reason.
    President:
  • Sanyo Master
  • 749 Answers
There is a reason for everything.
In this case you might need service of your power supply or a replacement buffer boards or , sometimes, a simple dismounting, cleaning and mounting of the TV.
But most of the time it would be around the Y-sustain and buffer boards.
Posted on Apr 18, 2014
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
SOURCE: screen goes black but still have sound
MINE TOO AND SANYO TOOK THIS TV OFF ITS SUPPORT WE SHOULD ALL SUE THIS COMPANY gcolella@snet.net
Posted on Jul 31, 2008
  • 71 Answers
SOURCE: i want by tv sanyo -modele-dp42746
whats the problem here?
Posted on Mar 05, 2009
dsacco86
  • 1077 Answers
SOURCE: our sanyo dp42746 went black made a pop sound and
Most likely a power supply board went bad. the pop sound is bad capacitor on the board. Most bad capacitors will look like this: 18976c2.jpg
The other picture below shows a normal capacitor in the middle, but two bad capacitors on the sides of it. One with the dome top and one leaking. 5d53c3a.jpg
You can try repairing the board by replacing the capacitors or replace the whole power supply board. Most replacement boards can be found at a good price at Shopjimmy.com or Ebay.
Posted on Dec 29, 2009
SOURCE: My tv went completely out. Is there a reset button
Try unplugging it. That is usually the reset.
Posted on Apr 02, 2012
If the converter goes out does the tv not do anything no screen light uponly red standby light?
if your question is that if cable or sat converter goes off for any reason , will your tv display a black screen , then the answer is yes , without an input most all tv sets will display the opposite of full white , this being full black , also any on screen displays might not work as well (no video to sync too)
Jan 10, 2017 | Televison & Video
Electric shock from handle
For safety reasons your electrical repair should only be done by a qualified technician.
Apr 18, 2014 | Vacuums
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
Screen blacks out on certain channels randomly..doesn't happen all the time audio still works the picture just goes completely black for a bout a second then reappears.. very annoying.it's new and it also...
Ur LCD inverter backlight board have problems,just not dead yet.When ur LCD inverter backlight board is dead.U will get only sound and no picture at all.
Feb 26, 2010 | LG 55LH90 55 in. LCD HDTV
Is it possible that my wireless network card is causing my laptop to not start. I have an Everex Stepnote VA4300M that goes to a black screen at startup. THe wireless card & monitor seem to have some...
it could be the culprit but it could also be corrupt system files, bad hard drive, bad motherboard. There could be a number of reasons why your laptop goes to a black screen.
The best way to tell if your wireless card is shorting out the motherboard to cause it not to boot is to take out the wireless card completely from the laptop and then turn it on and see if it goes past the black screen, if it does then you know thats the problem, if it doesn't then it could be some of the other reasons i mentioned.
Aug 10, 2009 | Computers & Internet
The plug that connects to the alternator has three
Yes the White wire is the reason. It goes to the Internal Regulator.
As you view the connector that plugs into your alternator, look at where the lock tab is.
Lock tab on TOP. The Black wire goes to the Left side. The White wire goes to the Right side.
The Black wire, ties into the Red wire down in the wire loom. (The Red wire goes to the starter solenoid, and this is connected straight to the battery. This is why the Red, AND the Black wire, are both Hot wires)
The White wire goes through the bulkhead wire loom, and to the bulkhead connector.
(Down under the steering shaft, and on the firewall, you'll see a rectangular Black box shape, with a Bunch of wires, coming into it from the engine compartment. The bulkhead connector is two pieces. Following it through the firewall, the other side of it is the fuse panel)
Where the White wire connects in the fuse panel,
it should go straight to the ACC fuse. (Accessory)
May 15, 2009 | 1987 Chevrolet Camaro
Wirless card for a laptop ?what wire goes to tha main - white or black?
The white or gray wire goes to MAIN and the black wire goes to AUX. For some reason no one can ever fully answer that question or they close the forum because it is old but when googled these questions still are valid and need to be available even today.
Jan 20, 2009 | Gigabyte GN-WIAG02 (GNWIAG02) 802.11g/b...
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Sanyo DP42746 42 in. Plasma Television Logo
121 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
