Question about Coffee Makers & Espresso Machines
Keurig now works ok until cup is put in - Coffee Makers & Espresso Machines
  • 24 Answers
If you mean the Keurig works without a K cup in it and dose not work with a k cup in it then you need to clean the k cup holder. Take a thin wire, I use a paper clip that has been straightened out. Inside the holder is the piercing pin with a hole down the middle where the coffee goes into your cup. Clean that hole out with the paper clip.
Posted on Jun 20, 2014
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: No water comes thru My Single-Cup Keurig Brewing System
Obviously a redtriction michael. They work like the old perculators . See if you can sccess and make sure the tubing is seated snd that the water is heating. Good Luck Michael
Posted on Oct 19, 2009
heatman101
  • 43501 Answers
SOURCE: My new Keurig coffemaker has started putting the
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
Why is my keurig 2.0 taking so long to preheat?
You need to run the cleaning cycle. Put some vinegar in it and pull some of it out in a cup. Then let it sit for a while so the vinegar can do it's work. Remove what's left by flushing several cups of water until you can't smell vinegar any longer.
Jun 17, 2015 | Keurig Coffee Makers & Espresso Machines
Keurig problems
what is your model and serial num ?
Sep 02, 2017 | Coffee Makers & Espresso Machines
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
How do I reprogram my platinum Keurig so it does not shut off
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
Nov 25, 2013 | Keurig Platinum B70 Coffee Maker
I have de-scaled and water pumps fine. Once I put the K-Cup in, the Keurig will not brew. I've cleaned the nozzle and ran the machine without a K-cup in and all is well. Once I put the K-Cup in no...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 14, 2011 | Keurig B60 Coffee Maker
I have a platinum Keurig coffee maker. I descale
Dear Rschles2,
I too own a Keurig Platinim.. I haven't a solution for your problem but I can tell you that your description of it is right on... I have had the same problem. Every month or two, my Keurig will decide I need a large cup rather than the size I chose. I've found no way to solve it... even unplugging the machine doesn't help. In the end, I remove my Kcup, and let the machine process a large cup of water. After that, it runs perfectly.... well, until the next time the Ghost appears.
maryann.
Jan 31, 2010 | Keurig Coffee Makers & Espresso Machines
Keurig B30 won't brew, no blue light comes on, top green light blinks...
Our problem was a glass cup. Changed cup to opaque cup and it worked ok, (optical sensor ?)
Nov 26, 2009 | Keurig B100 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
