Question about Motorola Mobility RAZR V3
Screen on Motorola v3xx doesn/t dim - ie it stays lit/drain power
This is an intermittent problem - I can shut it down and restart, but no guarantee the problem goes away. Very frustrating as it uses up all the power quickly.
I have the same problem every so often and found powering off, then back on, closing lid just after powering on will reset the display so that it blanks again. Just like you, I find this does not permanently resolve the issue.
Posted on Jul 27, 2009
LG 55LE5400 tv
It's a power problem , not sure of the model . The TV shuts itself down to save itself . It goes through a series of self checks before power up and if those aren't made it shuts down. If you are unsure of how and why I would suggest you take it to a pro
Jul 02, 2015 | LG Televison & Video
Screen will not stay lit
Check in the POWER OPTIONS section of the control panel if the display timeout for inactivity is too short. This is ONLY if the machine remains running.
If the whole unit is shutting down then likely your charger is not being effective. This problem can be with the charger OR the charging system on the motherboard of the laptop.
Apr 05, 2010 | HP Pavilion dv1000 Notebook
Can not read the screen--too dim
cant, its either the lcd itself or the lcd power inverter.
Mar 23, 2010 | Motorola Mobility MA351 Cordless Phone
I have a motorola razr v3xx. After using the keypad, the phone will shut off and then restart. What is causing this and how do I fix it??
If you can, perform a master reset on the phone. If the keypad restarts before you are able to get through enough menu's to do that, the phone will need to be replaced. If it's still under warranty (1year usually) this is considered a warranty covered replacement unless it's gotten wet or has any cracked plastic parts.
Sep 12, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
For awhile now my Razor V3xx has been shutting off by its self, the battery jumps around all the time like from full charge to almost dead to half way charged
try draining all the battery first, then remove the battery and put it back. It may just be a loose battery. Charge it until it is full.
Jun 26, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Mini display on motorola v3xx
try master resetting the phone.
if that does not work then take the phone and have them reflash the software on the phone.
Mar 29, 2008 | Motorola Mobility RAZR V3
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Razr v3xx celluar
Usually that only happens if the phone was just turned on, so the camera takes time to warm up. Try restarting your phone and try again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola v3xx
Have you tired to take the battery off let it sit for 30 seconds and replace the battery. then try and power on again
Dec 04, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
