Question about Whirlpool MT2110SJQ 1100 Watts Microwave Oven
Microwave won't start
Touch pad seems to be working. I put in the time to cook, press start, the microwave sounds like its about to start, but then stops. It was working perfectly before. Any thoughts?
    New Friend:
  • 35 Answers
Check the fuse usually a 25 amp appliance fuse behind key pad
Posted on Mar 18, 2014
jsrock516
  • 5911 Answers
SOURCE: Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Posted on Jul 31, 2007
  • 209 Answers
SOURCE: Microwave malfunction
this could be a diode between the capacitor and magnetron, (its like a fuse) i do not recommend self repair, but give you this info as a guide to what maybe wrong, microwaves contain high voltage and care should be used if you do attempt repair hope i have helped a little
Posted on Oct 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
biigg53566
  • 88 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
  • 1214 Answers
SOURCE: Whirlpool microwave cook light turns on but oven does not work
Check and replace the door safety switch.
Posted on Feb 15, 2009
Why are GE Profile JT930 touch pad numbers not working?
Seems problem with the touch pad. Try replacing the same.
Aug 16, 2014 | GE Appliances 30" Trivection Built-in...
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Burns my popcorn constantly. is there a different setting i can put it on?
    HELLO.
    Solution to your microwave problem is given as below.
    * 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
    * 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
    * 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
    * 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
    * 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
    * 6 Open the door when the timer reaches the "Off" position and take out your food.
    Thanks.
    Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
    I am having difficulty setting the clock on my Baumatic BAF9006 90cm dual fuel cooking theatre can you please help
    HELLO.
    Setting your microwave clock is explained below.
    It is a standard 12-hour clock (12:00-11:59) and does not show a.m.or p.m.
    The microwave oven and timer must be put off.
    1. Touch Clock.
    2. Touch the number pads to set the time of day.
    3. Touch Clock or Start.
    Thanks.
    Sep 21, 2011 | Microwave Ovens
    Everything works, clock, timer, lights etc. When I put in the time and press start, lights are on and cook time starts, but there is no sound and no cooking. Thanks
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101 ';
    Jun 08, 2011 | Amana ACO1860 Microwave Oven
    How do you set the power level? The model number is: JVM1730DM1WW The serial number is: MM901698B
    Assuming your touch pad is working properly, press Time Cook (for cooking) or Time Defrost (for defrosting) and then type in the length of time that you want the microwave to operate. Then press Power Level and type in a number from 1-10. Finally press Start. Depending on the GE microwave, the Power Level button may be above 2 or to the left of 0. (I've seen both keypad designs depending on when and where the microwave was manufactured.) If you press Power Level before setting the cooking time, the unit will reset when you press Time Cook or Time Defrost.
    GE has the manuals for some of their microwaves on their site. See http://www.geappliances.com/service_and_support/literature/ and enter the model number in the search engine.
    I hope this helps.
    Mar 02, 2011 | GE Microwave Ovens
    Touch pad not working properly
    That sounds like the interface controller which is just a little computer chip that cotrols everything and watches the signals from the touchpad is having problems. Usually these will behave like this and then just stop so your touchpad is totally dead. It may take out the time displays as well.
    If you have warrenty from GE or the store it will be covered. If you are not covered then it can cost about the same or more as a new microwave as they will have to replace the board. Check your warrenty's, then check the repair cost and check replacement costs. Usually a new microwave is the cheapest.
    Apr 28, 2010 | GE JVM1740DM Microwave Oven
    Microwave seems to run, but won't heat.
    We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
    Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
    Is there an internal fuse?
    there is a fuse, but if this was blown nothing would work, sounds like a capacitor on the control board,just replace the board
    Oct 07, 2009 | Panasonic NN-H764 Microwave Oven
    Manual for breville microwave bre799gmsse
    this feature allows you to program your oven to begin cooking automatically at a designated time of day. Simply touch Custom Help pad. Touch the number 3. Enter the start time. Touch Clock pad. Enter cooking program. Touch Start/Touch On pad.
    Jul 26, 2009 | Microwave Ovens
    Whirlpool MT2110SJQ 1100 Watts Microwave Oven Logo
    57 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
