Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
Machine buzzing.tub want turn. the power is on but the tub want turn and there is water sitting in the tub.
  • 35 Answers
The timer is going bad or is bad replace call appliance shop or look up on line
Posted on Mar 18, 2014
2 Suggested Answers
  • 464 Answers
SOURCE: Machine will not drain the tub or spin the
your problem still could be a bad lid switch not making. also, check your spin/agitate belt part #40053606. hope the attaced breakdown helps.250
Posted on Nov 08, 2009
Washing machine fills with water while sitting idle.
Another problem could be the inlet solenoid is failing to close properly, this could be caused by either an obstruction in the sealing part of the solenoid valve, a damaged or worn out seal or if the water pressure is too low. (some solenoids require water pressure to close off properly). To test this idea turn off the taps when not in use. If the water is still filling the tub, the back flow / syphoning idea may be valid. Also just to rule the idea out, turn off the tap to the machine and remove the inlet hose, if the tap "drips" this "trickle" of water maybe the culprit. If turning off the inlet tap fixes the problem you may need to replace the inlet solenoid.
Jan 08, 2012 | Whirlpool Duet GHW9150P Front Load Washer
When I went to do laundry today - I found the tub half full of water and then plastic tub that it sits in on the floor was full of water also (our washer is upstairs so it sits in a plastic tub in case of...
Sounds like the water inlet valve is faulty. It the part the allows water to come into the washer. When the washer is turned off or not running, water should not enter the machine.
It's a relatively easy part to replace. Unplug the machine, turn off the water faucets and remove the water supply hoses from the back of the machine. Remove the back panel and disconnect the inlet valve and replace with a new one. Replacement parts should be available at your local appliance repair house or online such as repairclinic.com. Hope this helps you.
Mar 08, 2011 | Kenmore 44102 Front Load Washer
I have a Kenmore 600 washermachine it won't spin or rinse. It would fill up with water and go all the way through the cycle until it got to the last rinse cycle and just stop and make a buzzing noise...
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
p.s the buzzing noise is the water pump humming because it can not spin the problem is definitly your water pump have it repplaced and it will work fine
please take the time to rank my reply if your happy with it.
Dec 01, 2010 | Kenmore Washing Machines
My washing machine is having trouble getting past the rinse cycle. I checked the hose made sure it was secure and clear of any debris hair etc. Then tried to resume draining but once it starts back up it...
YOUR PROBLEM IS DOOR SWITCH OR CLOGED DRAIN PUMP THER SHOULD BE A ACCESS PANEL FOR THE DRAIN PUMP SO YOU CAN GET TO THE PUMP AND UNSCREW THE OUTLET TO UNCLOG DRAIN
Apr 26, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Jacuzzi Bathtup pump issues
buzzing sound on a motor means it has almost burned out. you will need to replace the pump.
May 12, 2010 | Jacuzzi - Bathtub - Alcove - Navona -...
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
My washer wont let water in....it spins... but it wont let any water into the machine
Turn off water, take one hose off and stick in tub, turn on the water to this hose and verify your water pressure is there(no frozen lines) Look and see if screen looks clear inside valve before reattaching, turn water back on,,,,,,,,, If you hear a buzz when pulling out timer knob in agitation area it means you have power to valve, water valve is bad. (one solenoid for hot, one for cold)
If this is a standard top load unit(direct drive style) It has the pressure switch and timer controlling power to the valve
There are other answers on this site about removing the cabinet to service,
which you should check
Jan 09, 2010 | Whirlpool Washing Machines
THE TUB OF THE WASHER GETS REALLY LOW WHEN IS FILLED WITH WATER. NOW, ALSO THE WATER DOSENT COME IN WHEN I TURN IT ON
All top suspend tub washers drop down when they fill with water. And they rise again when they have pumped the water out. This is normal.
What is not normal is water not coming in.'
check following:
Water is turned on
Remove inlet hose and run water to see if it is blocked.
Clean the inlet filters.
If you hear a buzz but no water goes in the inlet valve needs replacing.
If yu use only cold water try swapping the cold hose onto the Hot inlet. Then select Warm Wash.
Then only turn on the Cold Tap.
This will allow you to fill the machine and do a wash.
Watch out though when it comes to the Rinse position......some machines only do a cold rinse, and because you have swapped the hose over to hot it will not fill to rinse the clothes. Until you can get a Tech to do the repair you can just use either a bucket to add cold water for the rinse or use the garden hose to fill the tub with cold water for the rinse.
Have yu got all that?
Oct 25, 2009 | Speed Queen AWS75NW Top Load Washer
Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
60 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Terry Schneider
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
