Vaillant aqua plus combination boiler
I have a vaillant aqua plus I change the fan and now is not starting up
  • 3 Answers
First off, I'm not familiar with this particular boiler. I'm in the USA. I believe this is manufactured in the UK and may not be distributed here.
Second, and are you sure you needed to replace the blower in the first place?
Those questions really need to be answered before making any accurate remote diagnostics. This is a pretty complex piece of equipment with costly replacement parts. Some diagnostic and/or service work should be left up to a professional in your area if you're really not sure of what you're doing.
We all (or most of us) like to save money by doing our own repairs. If you feel confident about working on this further you can go to www.vaillant.co.uk to get manuals and service info online. This info will do you much more good than my guesses will. This unit has a diagnostic/control board that will display most faults if you know how to use it. I looked at some of the info online. They have pretty good stuff available to you if you know how to use it.
After all saying that, it "could" be the pressure switch not closing after the fan starts. You didn't say whether the new fan is starting or not. On a call for heat (or hot water) the fan starts (controlled by the main control board), the pressure switch proves the fan is running (and venting combustion gasses out of your home), it most likely has to prove water flow. If all the proving is confirmed, the ignition sequence will begin.....ignition, prove ignition, main gas valve opens, heats water, so on and so forth......
Now, if you still feel confident to work on this boiler, go to Vaillant's web site and read the manual(s). If you're not confident, call the heating man in your area. Just be careful with gas, electricity and hot water!!
I wish I could have given you more info to actually fix your problem, but I need more info as to why you changed the combustion blower to begin with. What WAS it doing? what IS it doing NOW and so on....
Good Luck to you! Let me know what you find out.
Bob
lainemech
Posted on Mar 22, 2014
  • 13 Answers
SOURCE: hi,i have a vaillant turbomax
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Posted on Mar 03, 2009
  • 30 Answers
SOURCE: central heating boiler problem
this is probably a faulty diverter valve. more info needed
Posted on Mar 26, 2009
  • 30 Answers
SOURCE: Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
burty681
  • 56 Answers
SOURCE: i have a vaillant echo
Underneath the unit there are two white knobs with Closed on them. Open the left hand one, then the right hand one, watch as the pressure rises to about halfway up the dark grey area on the gauge. Then close the right then the left knobs.
Press the "-" button next the the radiator control will show the pressure in the system. This should be between 1.0 and 2.0 bar.
Posted on Jan 20, 2011
  • 30 Answers
SOURCE: a have a vaillant ecotec
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Posted on Aug 06, 2011
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
Aug 06, 2011 | Heating & Cooling
Hi my vaillant eco tec pro shut down last night showing fault f.28 and will not ignite today 08/01/2010 looked out side to see the condenser pipe was frozen i defrosted the pipe but boiler still wont...
Got exactly the same problem with mine. Manual says f28 = fault in gas supply, gas pressure too low. Boiler will ignite but goes out within minutes? HELP!
Jan 08, 2010 | KDS Valiant 6380iPTD-01 Notebook
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Boiler problem
check the air flow,venturi in fan and pressure switch
May 16, 2009 | Sun Time NCAA Purdue Boilermakers...
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
