Question about Maytag Ovens
Health issues My oven has been giving off a strange smell. A fews hours after having it in my house i began to feel lightheaded and my nose became clogged. I've been to the doctor and said i was coming down with a sinal infection.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
If oven is new. expect strange smell coming from the heating up of the new paint, just to be sure also check for gas leaks.
Posted on Mar 18, 2014
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have Jenn Air 30 inch slide in dual fuel oven
The self destruct or self clean feature has burnt the wiring inside your range... do not use that feature it causes the range to get too hot...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 26, 2010
How Seattle house cleaning is necessary?
Cleaning is the most important part of our lives because it is necessary for our good health. It is noticed that if you eat balance diet , do regular exercise but you do not care much about cleanliness so you can not be a healthier person. Without health no one can perform his activities even the basic work is not possible. Seattle is a place located near Washington and has a big population. Seattle house cleaning is essential because the life of the people is too much busy therefore it has become an important issue to keep clean your home if you are living in seattle.
Dec 27, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
I have Jenn Air 30 inch slide in dual fuel oven JDS8860BDP I used the self cleaning feature on my oven 2 days ago and it has had a very strange odor ever since. A chemical oily smell within a few feet...
heatman101
Apr 15, 2010 | Ovens
Our heater is 3yrs old and it is giving off a metalic smell when the hot water tap is turned on. We have had other hot water tanks and never had this problem. This is the first Moffat hot water tank we...
This may sound strange, but here is what to do. (the full explaination is rather long)
Turn power off to the heater. Turn off water supply to heater. Drain at least a gallon of water out of the heater and diconnect one of the pipes at the top. Add a gallon of bleach. Reconnect pipe. Turn water back on to heater and run each hot water faucet in the house until you can detect the odor of bleach, then shut them off. Let the system stand for at least an hour. Now, turn each valve back on and run until the odor of bleach is gone. Turn power back on to heater.
Nov 09, 2009 | Moffat E32 Full Size Electric Convection...
Alarm on NEFF U1721
It might be the volume control.
Try pressing the minus button a few times. The loudness should cycle between low, medium and high.
Jun 16, 2009 | Neff U1721 Double circotherm Electric Oven
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Glass top and oven 7 months old still has the new oven smell
possible that the insulation that surrounds your oven cavity has yet to fully cure, i would run a clean mode, this will get the unit to max temp fro 3 hours, fully curing any insulaton for sure
Dec 02, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven
sounds like a oven valve is not opening all the way...
part # VALVE, OVEN 74006427
Aug 16, 2008 | Ovens
SA999X wont turn off & smells
suspect your electrician wired it up wrong
Feb 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Gas Smess
the gas might be too high, try turnin it down, or their is a falt with the oven
Jan 13, 2008 | Ovens
Ovens Logo
67 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
