Question about HP Photosmart C5180 All-In-One InkJet Printer
Printer wont shutdown after paper jam - HP Photosmart C5180 All-In-One InkJet Printer
After removing paper jam, which may have been caused by using typing paper,which was a much lighter weight,computer was shut down,on startup printer had shutdown,no further problem.
Posted on Jun 19, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Wont print....it says paper jam....but not paper is jammed. what to do?
make sure you check the manual and open all inspection areas to remove any scrap paper, its normally the cause
Jul 21, 2014 | Canon PIXMA iP1600 Printer
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
System error 80:01
System Error:
81:01
Description:
Paper-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
Perform the Paper Advance Test.
Replace the Encoder Disk Assembly
Nov 05, 2012 | HP DesignJet 500ps (42 in.) InkJet Printer
There is a paper jam
The solution depends on which type of printer and which model it is. Generally, you must open the access door/compartment and try to get the paper out. I had a bad paper jam last week and I had to open the access door (same access area you use to change out the ink cartridges) and do a lot of pulling and maneuvering. Don't force the paper too much or you might break the printer.
Mar 06, 2011 | Kodak Office Equipment & Supplies
There is visibly no paper jammed have checked removing the cartridge.yet I get A msg that the paper is jammed
Have you check paper jam from the fuser? You have to open the fuser door which is at the back (on the rear) of the printer, after pulling out the fuser, you'll be able to do that.. Also check the paper carriage (passage after the Tray).
If there's nothing, then, remove the cartridges and shutdown the printer, leave it off for few minutes and then again restart it while pressing the power button and if the error still there, press the "Go" or "Ok" button and see if it helps or not..
Good luck.
Thanks for using FixYa.
Jun 22, 2010 | HP LaserJet 1018 Printer
Printer says I am out of paper when in fact the paper in in there
its jammed.. remove all paper. switch off and turn back on.. also shutdown all printer software which will clear and queue and jams..
Jul 24, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Paper stops half way, I get a message saying it's a paper jam or misfeed, but I can't find anything jammed
try to shutdown your printer and then ....arrange the paper properly on the tray or add some ..and then print an alignment page on it.....
May 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
Dispalays Reads paper jam and wont disappear
Unplug the power cord then put it back up. This restarts the printer again in case the on/off button does not work to turn the printer off. Then check if there's a paper jam. To do this open the scanner lid and also the glass lid, just the way you access the inks when replacing them. Check to see if there's any paper stuck underneath the inks by the printer rollers along the paper path.
Apr 06, 2009 | Lexmark X4650 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
