Question about Hardware & Accessories
Heil ch5524vkd1 i need to replace the top cover of my outside unit. The fan attached to the top cover. having a hard time locating the part number? any ideas
  • 24 Answers
SOURCE: Heil 9000 Air Conditioning Unit problem. . .
It could be the fuse in the disconnect box are no good.
Posted on Apr 24, 2009
james3751
  • 614 Answers
SOURCE: Heil Max Performance 10 Heat Pump not working
First check to see if you have afloat switch inside the air handler ar underneath the air handler. Its purpose is to shut the outside ac off if the drain stops up. Very common. If this is OK take cover off unit and with screw driver push in the contactor. It is located about the middle of the panel. It has main power at the bottom. If unit comes on you cave a control voltage problem. Meaning something is not allowing 24 volts to the contactor. If your out of Refrigerant the low pressure swich will have it off. Call a service tech. Rusty
Posted on Jun 09, 2009
TheMobilian
  • 8220 Answers
SOURCE: ruud heat pump outside fan won't run
Tell him to make tight connections.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 23, 2009
  • 308 Answers
SOURCE: The outside unit is not working on my Heil Air conditioner
The attic fan is not a part of your a/c system, and you should not run it while you are running the a/c. If you are currently using the attic fan, it is possible that someone wired it so that the a/c won't turn on while the attic fan is on. Otherwise if the thermostat is set below room temp, and says it is calling for cool, then the problem is most likely coming from an issue at the outside unit itself. Make sure to check your fuses, at the fuse panel and outside breaker. Hope this helps
FYI.. the only part of the system that might use batteries is the thermostat.
Posted on Jul 28, 2009
  • 222 Answers
SOURCE: Have broken the glass on a new world hotplate
hi...first thing to do is canvas the price of the ceramic glass top,coz the price of the glass is half or more compare to the new one..do u think if u buy a glass only it is reasonable or waste ur money?then dont try to fix it by it ur self,coz the glass u buy is no warranty for wrong instalation.call an expert technician to do it to get an assurance for the warranty for installation.
Posted on Sep 13, 2009
Locating filter location on my Heil variable speed furnace G8MTLO701412A1
If the unit is a packaged unit (blower and everything is outside), it may be like mine. Mine has a narrow and tall cover that pulls up and off to reveal the slide in from the side filter. Mine is situated just behind the unit, between it and the large ductwork going under the house. Took me a while to find mine as well.
Jan 05, 2018 | Cars & Trucks
Where can I get a manual for Heil 5000 unit
http://www.goheil.com This is a website to start with. You will need to find the specific model number on the unit. For your records you should copy all information on both inside and outside units.
Sep 01, 2014 | Heating & Cooling
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
How long is the compressor in my heil max pro 10 waranty good for
Not sure which model number the Heil Max Pro 10 warranty uses. Heil will usally place the model number on the side of the outside unit or inside the cabinet for thee Inside unit. Click here for a direct link to=> Heil HVAC
Use care when reading any warranty because the wording is mostly written so you do not understand.
To help you decide which Heil product and warranty protection is best for you, select from the following at-a-glance comparisons.
Please let me know If I can help you with other question, Thank You, Sea Breeze
Aug 31, 2011 | Heating & Cooling
In my Heil heat pump outside unit, I hear a click and the unit tries to start and then stops. I have replaced the electromagnetic contactor coil and the capacitor. The problem still exists, no...
If the top of the compressor is hot to the touch after you hear it try and start, then shuts down, it's probably locked up. The compressor will need to be replaced, or you'll need to replace the entire condensing unit. It's best to replace the entire condensing unit because you'll have a warranty on the entire unit for just a bit more money.
Jun 23, 2011 | Heating & Cooling
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Jul 28, 2009 | Heating & Cooling
Jun 09, 2009 | Heating & Cooling
I Am looking for heil NPA HC36 AKOL air conditioner wire diagram
You will need to contact a Heil distributor to get a wiring diagram. Or you can try a dealer but they probably won't help you fix your own unit. That would be taking money out of their own pockets.
Mar 10, 2009 | Heating & Cooling
Hardware & Accessories Logo
59 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
