Question about Apple Computers & Internet
Sumvision egem external hdd
Hd from old (2010) macbook pro placed in sumvision egem enclosure to be connected to new mbp (2013). worked initially but is no longer recognised when plugged in to usb port, despite hd spinning and green light on the enclosure.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
More often hardware compatibility issue, try using different usb cable first,
Posted on Mar 18, 2014
myjosh007
  • 530 Answers
SOURCE: USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
Posted on Feb 23, 2009
l_hartong
  • 13 Answers
SOURCE: I have a new Macbook, but it doesn't have a
Buy a USB card reader, this will show your card (which you used in the camera) as a normal disk in finder
Posted on Jul 04, 2009
damien729
  • 221 Answers
SOURCE: Macbook Pro mouse working temperamentally
Hello, it seems that the problem comes from your mouse: can you test your mouse on another computer and check if it does the same? If yes, you'll have to change the mouse
jgcalifornia
  • 160 Answers
SOURCE: I want to connect dcr-trv70 handycam to macbook
does the mac recognize the handycam at all? or is it just in imovei..
Posted on Jul 24, 2009
Macs R We
  • 481 Answers
SOURCE: 16GB USB Memory Stick not readable by Macbook
It's possible it was just subjected to a static shock and got scrambled. As long as the data previously on it was not important to you, you can re-initialize the unit (provided it has not been physically damaged).
In Applications/Utilities, launch Disk Utility. Plug in the USB stick. Choose the stick by name in the left side panel, and click the Partition tab. Choose 1 partition. In Options, choose GUID Partition Table. Click Apply. This should reinitialize your stick.
Posted on Apr 03, 2010
Connect iphone 4 to Macbook via Bluetooth
Are you running Mavericks on MBP and IOS 7.1 on Iphone 4?
Oct 07, 2014 | Apple MacBook Pro Laptop Computer with...
MBP cannot start black scteen with boot up sound
Hi JJ Su,
To connect an external monitor to your MacBook Pro, you will need an adapter that connects to the mini-display port on the MBP, and has another plug that is appropriate for your external display {VGA or DVI}.
Take a look at Amazon to find a relatively inexpensive adapter if you don't already have one.
-Please make sure that you order the right kind of adapter for your MBP since there Apple has used 2 different kinds of ports depending on the particular model!
FYI, if the external monitor doesn't work either, then you probably have a bad GPU {Graphic Processor Unit} on the motherboard. IF the external does work, then you either have a bad internal screen, or some bad connectors/wires inside the MBP...
Hope this helps & good luck!
Apr 15, 2014 | Apple Computers & Internet
Clone mac drive
As an alternative, you can try making a new Time Machine backup from the files of the old HDD. Install Mavericks from scratch on the SSD and then transfer the documents needed back from the Time Machine.
I would recommend installing fresh OS X when upgrading from HDD to SSD anyway.
Here is how to make a bootable USB stick for installing Mavericks:
http://www.youtube.com/watch?v=2or1Wthkl1w
Do you need any additional assistance?
Jan 16, 2014 | Apple MacBook Pro Notebook
My macbook pro doesnt recognize my toshiba canvio 3.0 external hard drive
When have you bought you mbp ?
Your External HDD is in which format, Do you have an app like NTFS for mac osx, or Tuxera NTFS on your MBP if your HDD is not formated as MAC OSX drive. .....
Nov 30, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
Every time I log on I get an error message relating to my sumvision 2.5 sata to usb 2.0 external hard drive. The message is E:Desktop refers to a location that is unavailable. It could be on a hard drive...
an external hdd is not the same as a network or memory in a computer,it can only be accessed by a human,not automatically when you log in,if you have files or drivers on it,you need to put them on the computer.
May 06, 2017 | Computers & Internet
This was bought from a friend who no longer has the manual and I am still not quite sure what it is or what it does.
This is a case for 3.5" HDD that make any 3.5" HDD become external Drive. Here's the product description from Amazon :
The CoolMax HD-360-U2 USB 2.0 3.5" External Hard Drive Enclosure is portable size and excellent quality. The 3.5-inch hard drive aluminum external enclosure is specially designed for high capacity hard drives. And its aluminum material design is great for heat dissipation, so you don't need to worry about your hard drive overheating anymore. The HD-360-U2 Series gives you the freedom to work anywhere, no matter if you're in the office, at home or on the plane. This portable 3.5" HDD external enclosure provides maximum durability, flexibility and portability with various interfaces. Once you download your information to the HD-360-U2 series, you can connect it to any system and gain access to your programs and data files anywhere. With built-in hot swap technology, you can connect and disconnect the drive any time.
Features
  • Supports high speed data transfer rates up to 480/400 Mbps
  • Fully compatible with 3.5" IDE 133 HDD
  • Soft-start for slow turn-on feature prevents high inrush currents when initially powering capacitate loads
  • Anti-shock design, protect the hard disk from damage when moving it
  • Insulating designed PCB
  • Aluminum case transmits the heat quickly
  • Powered by a DC 12V-2.0 A transformer
You can visit the website : http://www.coolmaxusa.com/extenclosure.asp?item=3.5 for more details
Feb 07, 2011 | Coolmax HD-360B-U2 USB 2.0 External Drive...
I have one of these harddrives, and bought a new computer. I now want to use it as an external Hard Drive, but do not know how to. Since I bought a macbook pro, this might be hard. It would be best to just...
The best option would be to purchase an external enclosure for your hard drive. Once inserted and connected to the enclosure you will be able to connect your hard drive to your pc/mac via a usb cable.
Hope this helps!!
Please rate!!!
Jan 03, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Sumvison cyclone HD media enclosure transfer issue
You can get replacement remotes for it on ebay for about £10
Sep 26, 2009 | Sumvision Sempra PRO Digital Media Player
WD 500GB MyBook stopped mounting on MacBook Pro
Have you tried it in another computer? I think these kind of problems can sometimes be caused by USB voltage problems, especially if your MBP has an old battery (I believe the battery is used as a power buffer to keep size of transformer down). If that doesn't work, see if you can find someone with the same HDD power supply and try switching that over. Failing that it's data recovery, you may be able to do this yourself by switching the actual hard drive into a new enclosure.
Aug 23, 2009 | Western Digital 500GB My Book Pro-External...
Macbook Pro goes from gray apple screen to black
Try booting into single user mode by pressing Command+S while booting. You should then be at a prompt. Type in:
fsck -f
and press Return. Let it run and see if it corrects any filesystem issues, then reboot when it's done.
Apr 25, 2009 | Apple MacBook Pro PC Notebook
Computers & Internet Logo
64 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
