Question about Mattel Hot Wheels Mega Air Jumper Monster Jam
We just bought mega air jumper yesterday and it already won't jump
Need Manuel for the ever start 750 a amps jumper starter with air compressor. I already have purchased the item.
https://dogdowndingper.files.wordpress.com/2015/07/everstart-jump-starter-300-amp-instructions.pdf
Nov 02, 2017 | Air Tools & Compressors
John Deer 175 hyudro tractor with Kawasaki FC420V-DS00 engine. Starter stopped turning engine over yesterday.
you can tell by bypassing the solenoid with a jumper wire, just touch it from one terminal to the other and if starter jumps you know it is good but only jump for a second do not connect only touch.
Jun 11, 2017 | Cars & Trucks
When i jump off my 2001 Mitsubishi Diamante my brake and battery lights are on at the same time, but when i disconnect the jumper cables the car will only stay running for a few minutes and then cut o
I would take it to auto zone or something like that to see if the battery is any good or good right to the store where you bought it and ask them to test it for you.
Jan 02, 2013 | 2001 Mitsubishi Diamante LS
My truck won't even turn over. I can jump it and it runs but when shut off it won't startagain
if it turns off as soon as you take of the jumper cables the problem is the charging system. it could be the alternator or relay or a fuse. and after that you need to charge the battery.
Aug 05, 2012 | 2005 Nissan Frontier
Removing starter on vangraud 14hp b&s
take a pair of car jumper cable and jump from the battery to the starter if it cranks over take a look at your safety switches start with the one on the clutch/brake pedal
May 26, 2012 | Mtd Garden
Why won't my car stay on after I jump the battery
If it dies after you remove the jumper cables, then the alternator is not charging.
Aug 20, 2011 | 1990 Lexus ES 250
Suburban won't start, bought a new battery but does no thing, when jump started it stays running until it is shut off and will not start again
If you can jump start it and it stays running....I am assuming that you connect the Jumper Cable Ground to something other than your battery. If so, Your negative battery cable is suspect. Check both ends for ANY corrosion or loose connections.
Aug 18, 2011 | Chevrolet 1500 Cars & Trucks
How do i jump my 1997 dodge stratus
  • Ensure your Stratus's ignition is in the "Off" position, and turn off anything that uses battery power, such as lights, radio and heater blower. Park the booster car close enough to the dead car that you can connect the jumper cables to both batteries, but make sure the two vehicles aren't touching. Connect one red (+) clamp of the cables to the booster battery's positive terminal. Connect the other red clamp to the Stratus' "Remote Terminal." The terminal is located next to the air filter assembly, and is marked with a "+" and the word "Positive." Dodge uses these remote terminals to reduce the risk of explosion caused by sparks near the battery. Connect one of the black (-) cable clamps to the negative terminal on the booster battery. Connect the other black clamp to the negative "Remote Terminal" on the Stratus, located on the opposite side of the air filter assembly from the positive terminal. It is a marked with a "-" and the word "Negative."Start the booster car, if not already running, and apply slight pressure to the gas pedal to make it idle faster. Wait a few minutes and attempt to start the Stratus. If it cranks a little, but still won't start, continue charging the battery. Once the Stratus starts, leave it running and disconnect the jumper cables in reverse order of the way you attached them.
  • May 23, 2011 | 1997 Dodge Stratus
    I had to jump my 2006 GMC Envoy Denali, got the car started but now I have no electrial except headlights. Is there a master breaker somewhere?
    How did you jump it? If connected the jumper cable to a bolt stud on the fuse panel, you might have blown the Mega Fuse.
    Sep 10, 2010 | 2006 GMC Sierra Denali
    Mattel Hot Wheels Mega Air Jumper Monster Jam Logo
    Top Mattel Toys Experts
    thegtw
    Nikki  Mclean
    Nikki Mclean
    ray gallant
    Are you a Mattel Toy Expert? Answer questions, earn points and help others
