Question about Bosch Washing Machines
My Bosch washer has started to heat the water to a very high temp. eventhough i put it on a cold wash. It heats it's own water, so please don't suggest turning off the hot tap. the water is so hot, when i open it the clothes are nearly too hot to take out and has wrecked some clothes. Please help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Replace thermostat controls/sensors on washer
Posted on Mar 18, 2014
Jimster
  • 240 Answers
SOURCE: Hot/Cold water knob will not work on washing machine
Does the water flow when you have it on warm or cold settings?  If on warm setting and water flow is cold, its probably the mixing valve.  This part isnt that expensive, and not that hard to replace.  Remove the two front console caps, remove the two console hold down screws then flip the console out and then over the top.  You will see two gold cabinet hold down clamps, pop them out, the lift the whole cabinet off the unit.   You will see the mixing valve right where the inlet hoses connect to the machine.  Let me know if you need further help.
Posted on Oct 17, 2007
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
SOURCE: clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Posted on Oct 24, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Posted on Oct 31, 2008
SOURCE: Washing Machine keeps stopping and says "water tap closed?"
Wonderful!! Would you mind giving me a "problem solved" rating -- there should be icons on the screen to do that.
thanks...
Charlie
Posted on May 29, 2009
Bosch exxcel washing machine not heating water
Are you sure it's not heating the water? The only time it heats is when it takes the detergent, all rinses are in cold water only. To test the heater, put the dial to the OFF position, press and hold the start button whilst turning the dial one click to left (30 easycare) when the two middle lights come on or 888 in display (if there's a display), take your finger off the start, turn the dial to 90 cotton (the long way, counterclockwise, not thro the OFF) press start, the tub will fill and it will do a stationary heat, you should hear the element/water making a noise like a kettle boiling. Leave the machine like this for a few minutes. Put dial to off until the door lock disengages and touch the water to see if it's warm. Put the machine on drain to clear water. If there is defo no heat repost and I will give you step by step of changing element.
Cheers Roni
Mar 01, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Does my Bosch SHU3032UC have a heat booster?
The dishwasher has a built in instantaneous water heater, so even if the water feeding the d/w is cold the machine will heat it the the temp required for the cycle you have choosen. Reducing the temp will not effect the wash quality at all, in fact having a lower temp or cold water filling the machine will make the drying cycle at the end of the program more effective.
Hope this helps, please leave feedback.
Jul 27, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
What is the amount of time for a regular wash? Time on the plus wash?
a regular wash should take about an hour and a half. plus wash would be longer only because it heats the wash temp hotter.
wash temp is generally around 140 degrees
and your rinse is around 161 degrees.
your flow through heat assembly heats the water at 2 degrees a minute. so it can take anywhere from and hour and a half to two hours for a full cycle.
try turning your sink on hot water until you feel hot water coming out then start the dishwasher so it doesnt have to heat cold water up to those temps. it should run a little shorter.
Feb 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
No Cold Water Wash; Only Hot
When doing a hot wash the machine is designed to take both hot and cold water. This is because it can heat the water to your selected temperature but if the water coming in is too hot it needs to cool it down to avoid heat damage to your laundry.
Hope this helps & thanks for using Fixya.
Dec 18, 2008 | Bosch Axxis WFL 2060 Front Load Washer
BOSCH DISHWASHER RUNNING TOO LONG PROBLEM
Bosch dishwashers are designed to heat the water to temp. However it has a 3 hr default if it doesn't reach temp. Start the cycle and see if after 1 hour if the water is hot or cold. If hot, then it is heating the water and the water coming in is just too cold. You may try running the water at the sink to get it hot there first before starting the dw. If the water is cold, then your unit isn't heating the water. At this point I pull the outer door panel, find the largest wires on the control unit and put my meter leads on them then start the machine. You will see 120 volts on your meter. Start the machine in light washes and with in 10 to 15 minutes you should see 0 voltage. Than means the relay has closed in the control and the hot line of the 120 volts is being sent to the heater. If this never happens, then you have a bad control. Bosch dishwashers have a 5 yr part warranty on the electronic control. Now If you get the 0 volts, I will put my amp meter on one of the same wires and check for 9 to 11amps. If that isn't there, then you have a bad heater assy. Hope this helps
Jan 04, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
