Question about JVC KW-NX7000 Car GPS Receiver
Solution for reset 08 code
I reconnected the bluetooth plug twice already.it works for a bit then now showing reset 08 bluetooth not connecting again.
Since the iOS 9.1 update, my iPhone 5 has lost all Bluetooth connections and I cannot make them reconnect?
  • Turn off Bluetooth and restart your iPhone or iPad.
  • Repair the Device you Connect: Go to Settings > Bluetooth > Choose the device you are having issues with > Tap on the info button next to the device > Tapon Forget This Device.
  • Reset Network Settings: Settings > General > Reset > Reset Network Settings. You need to set up your Wi-Fi connections again after doing this.
  • Try restoring your iPhone: You can restore your device from iTunes or iCloud. Bear in mind that it will erase your existed data so you'd better back up your iPhone or iPad in advance.
You can check this article to learn more about how to fix iOS 9 problems
The Most Common iOS 9 iOS 9 1 Update Problems and Solutions
Nov 27, 2015 | Apple iPhone Smartphone
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
My iHome iBT60 has a low volume when connected through Bluetooth. I've tried connecting & reconnecting it twice, and it didn't work. Has anybody had success troubleshooting thi
Turn up the volume on your iPhone. Also, try connecting your iPhone or any other media player, e.g. computer, to the AUX IN jack on the speaker and see if the volume is higher for that connection.
Jan 01, 2015 | iHome iBT60 Bluetooth Rechargeable Mini...
Noisehush n500 bluetooth
you can check the battery life of the bluetooth,if ok then you need to back up your files and have a reset your phone into factory default and paired it again....
May 14, 2014 | Cell Phones
AVH-p4450bt can't connect to bluetooth saying Error-10 help!!! :(
my avh p 4450 radio shows error10 don't want to pair up how do I reset radio I did plug it out already and theres no reset button on radio thanx
Feb 02, 2013 | Pioneer Avh-p4450bt 7" Bluetooth Gps...
My bluetooth stopped working.
Change your OS windows to windows 7
Apr 24, 2012 | Dell Studio 17 Notebook
My gm bluetooth loses its pairing every time car is turned off and I have to re do everything
Try doing this: Ask your dealer for the latest TMB concerning bluetooth and the connection problems with a mobile phone. There is a software update for that, and you'll have to take it to the dealership - the bulletin number is #08-08-46-008 After the upgrade, it should work flawlessly! :)
Oct 23, 2009 | 2009 Chevrolet Malibu
Modem won't connect to internet. OS: WinXP Pro SP 3. ISP: Earthlink DSL. Modem: ZyXEL P-660R-D1 (supplied by Earthlink) connected to computer with ethernet cable. Modem includes double filter for phone...
maybe you have to wait for your provider for them to isolate the problem, it seems that your modem got hit maybe by high surge. ask them to bring a spare modem for isolation.. there is no way for you to isolate the problem coz you've already done the basic....
Jun 19, 2009 | Computers & Internet
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Phillips gogear 6025 is not recognize by computer, code 28
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 17, 2009 | Philips SA6025 Digital Media Player
JVC KW-NX7000 Car GPS Receiver Logo
44 people viewed this question
Top JVC GPS Experts
Are you a JVC GPS Expert? Answer questions, earn points and help others
