Question about Homedics El 200 Elounger Massage Recliner
Control panne I want to know how to take the controll panel off
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
The control panel for my Amana oven, model ACS3350AS, turns off mid cycle. How do I know if the panel is fried or it's something else? Is the control panel easy to find and install?
the fitst thing i would do is check the incomig power. make sure you have constant power ad that the range isnt loosing power. if your power is good, then you may have a bad control. go to www.searspartsdirect.com. type in the model and you can view the price for the control
Nov 25, 2011 | Amana ACS3350AS Gas Kitchen Range
I cannot print or copy with my HP LASERJET MFP M2727 NFS because the control panne show this error: SCANNER INITIALIZING ERROR 5. The only thing that is suggested is to turn on the device. When I turn on...
This sounds like a Scanner/Flatbed Problem. This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Jan 27, 2011 | HP Laserjet M2727nf Multifunction Printer
The handle is broken how can it be replaced. it cannot be opened
if it cant be opened from either side( child lock is on...etc) then the only way to get it open ist to try and rmove the inside door panel without breaking it< which is pretty much impossible. once you get into the door panne you can open the door by pushing the rod that used to connect to the handle. cheapest rout is to find a door panel and a door handle at a junk yard
Jan 18, 2011 | 1996 Ford Contour
It's flashing code F-28
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. Panne de communication entre le module de commande central et le module de commande du moteur. Possible Causes/Procedure 1. Unplug washer or disconnect power. 2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU). - Check connections of the CCU board within the housing. - Make sure all grounding switches are engaged. 3. Check the drive system for any worn or failed components. 4. Plug in washer or reconnect power. 5. Verify CCU operation by running a Diagnostic Test or any cycle. 6. Check the MCU by looking for operations of the drive motor. 7. Check the drive motor for powered rotations. 8. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors.
Nov 26, 2010 | Kenmore HE2 Plus Front Load Washer
Code panne C 6000
fuser code..you have to replace the fuser unit
Jan 08, 2010 | Copystar CS-2550 All-In-One Printer
Hello, my dryer says control locked. i dont know what to do.
The following link explains how to unlock the control panel on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
This is actually a designed safety feature of the dryer that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can be inadvertently locked by leaning on the control panel, or during power outages. The instructions are printed on the front panel of the washer and are included in the owner's manual.
If you require further assistance, please let me know. I hope this helps you.
Oct 12, 2009 | Whirlpool GEW9250 Electric Dryer
I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Aug 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Controll pannes has dim lights and wont respond to touch
It sounds like a bad timer board . If you unplug overnight you allow discharging the capacitor on control board, that is the reason why it works next day. Check if the power outlet is grounded properly, and test a different outlet. If that does not fix the problem, then test and eventually replace timer board, motor control unit or any other control board present (dryness control if present).
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 02, 2009 | Whirlpool GEW9250 Electric Dryer
Sound Problem
Most of the new motherboards u need to install a Windows Xp patch called Microsoft UAA Bus Driver. Click the Link and download the driver. see if that helps you.
Dec 14, 2008 | Intel D102GGC2 Motherboard
Homedics El 200 Elounger Massage Recliner Logo
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
