2006 Jeep Liberty ac not working,fuses are fine,relay good replaced low and high pressure switches refrigerant level is good still won't work
Check for battery voltage on the dark blue/yellow wire in the connector at the AC clutch with engine running and AC on. If no voltage, yank the AC relay and check for battery voltage on terminal 86 in the relay socket. If no battery voltage on that terminal, check fuse 21. If yes, check for ground on terminal 85 in the socket. If no ground, then PCM isn't commanding the AC clutch on. Check for voltage on the dark blue/yellow wire at the low pressure switch and good ground on the black wire. The PCM provides power to the low pressure switch which then goes to ground. The PCM is looking for a large voltage drop if pressure is above 34-38 psi. If pressure is below that, the switch will be open, so the PCM won't see a voltage drop and will prevent AC clutch operation. The high pressure switch should be closed at pressures below 270-330 psi
