Question about RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood rv water heater
Atwood 6 gallon water heater lights but the ignitor keeps sparking even though it is lit and then it shuts off in 4-5 seconds
  • RTO Master
  • 5,245 Answers
tborn6
  • 700 Answers
SOURCE: atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Posted on Jan 21, 2009
  • 80 Answers
SOURCE: the water in my atwood electronic 6 gallon water
It sounds like your thermostat for the heating element is stuck on.
Posted on Oct 02, 2009
SOURCE: I have an Atwood 6 gallon electronic start water
Open following link for Atwood troubleshoot resources to identify product and look at manual with parts lists.
http://waterheatertimer.org/Atwood-water-heater-resources.html
Add a comment to this thread saying how you solved problem to help others who have same issue
Posted on May 28, 2011
motor1258
  • 6674 Answers
SOURCE: I have an Atwood 6 gallon water heater with
Obviously something ( propane or carbon monoxide ) is leaking inside the unit either while water heater is running or after. I hope I don't need to warn you how dangerous this can be, and that you should have it checked by a qualified technician A.S.A.P. , and propane should be shut off until such.
With that said, 3 things come to mind that should be inspected or considered. Look at where propane line comes through housing of water heater and attaches to gas valve. There should be a rubber grommet in the hole and it should be air tight so as not to allow any fumes or gas to enter back inside trailer. If it's not air tight, use a silicone type sealant and seal it good at that location. Another thing I would look for is any window or opening above water heater that may be allowing fumes or gas to enter inside trailer. Next, I would take a spray bottle, fill it with water and squirt some liquid dish soap in and mix it to test for leaks around all fittings at water heater, and especially spray orifice where gas comes out of valve and enters burner tube, when heater is off, to see if any bubbles form at end of that orifice, which would indicate a leaking gas valve. Again, I urge you to have it checked by an experienced technician for the safety of yourself as well as your family and friends.
Posted on Jun 25, 2011
motor1258
  • 6674 Answers
SOURCE: I have an Atwood electronic
Use a multimeter or test light for 12volt DC, and check at gas valve for 12 volts when it is trying to ignite (you here/see it sparking ). If no 12 volts to there, it will not ignite because no gas is flowing through valve. Try removing the connectors on the circuit board/module ( with switch in off position ) and cleaning the board contacts with a pencil eraser, and spray WD-40, or preferably an electrical spray/contact spray on connector contacts and retry. Board, or module may be located outside , or inside on top of tank, depending on what year and set-up. If that doesn't work, there is a small cut-out enclosed in plastic sleeve right near pressure relief valve area, that looks like a resistor that may be faulty. Remove it from the circuit and try it then. Simply pull the wire off at thermostat, pull that out of the sleeve by disconnecting it from the female spade connector, then put female spade where it used to be on thermostat terminal. If it works, buy a new thermal cut-off. If all that is done and tried, and still doesn't light, replace module.
Posted on Aug 12, 2011
I have an Atwood 6 gallon electronic start water heater in my 1999 Pace Arrow Vision motorhome. The ignition spark does not operate when I try to turn on the heater from the control panel in the RV. I can...
Jan 25, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a Atwood dsi water heater that after hot it wil keep lighting run a few minute and shut off and it will keep doing this but some times off for hours normal. I changed thermostats no difference
Don't forget pressure relief valve as well. Small drip is acceptable though. Double check by-pass valves are in proper position as well.
Thermostat if working properly would have to sense (feel) cooler water at it's location in order to re-ignite system, which makes me think, cooler water is circulating through there somehow.
Dec 14, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood water heater problems
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
158 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
