Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
Infuser not tamping grounds - Magnifica DeLonghi Coffee Makers & Espresso Machines
Hi there. problem with my La pavoni PL-16. No coffee comes out. The vapour its ok, it comes out but from the place the coffee should comes out, it doesnt. With or without the the filter holder. Whats...
Hi if there is Vapor coming from the grouphead when the lever is down then I would guess there is a problem with the seals around the piston and possibly elsewhere. Here is a link to a goos site that looks at repairing La Pavoni lever machines. Good luck.
DIY
dr pavoni
May 29, 2014 | La Pavoni Lusso PL-16 Espresso Machine
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
Coffee exits portafilter too quickly. Rocky grinder with burrs set as close as possible. Grinders and rubber recently replaced.
Sounds like your group handle needs a new basket (the piece with all the small holes in it). Presuming that grind is set correctly and that coffee is being tamped enough? Sometimes as the basket gets older, the holes can get larger and coffee doesn't have enough time to infuse with the coffee before exiting.
Mar 30, 2011 | Rancilio Silvia Espresso Machine
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
The brew unit is not tamping the ground coffe properly.
Give the brew unit a good wash,then lube all the moving parts with food grade grease.
If you are able dismantle the brew unit and wash in warm soapy water,this removes coffee and any old lubricant.
Feb 21, 2010 | Gaggia Titanium Espresso Machine
Coffee tastes waterdown
for grounds you need to tamp the ground hard,. Fill the port a filter to the top then tamp it until the little line is showing. Also what may be a problem is the grind is too fine, or too course
Feb 12, 2010 | Coffee Makers & Espresso Machines
The filter basket on my FrancisFrancis X5 sticks to the machine.
Place a glass under the filter basket. Do not return the portafilter. Pull another shot. The pressure will push the filter basket off.
Apr 01, 2009 | FrancisFrancis! X5 Espresso Machine
Saeco portafilter instructions
When using ground coffee, use coarser grind like the size of table salt grain. Feel the ground coffee for adjustment. Do not tamp, just level the cup with coffee grounds and lock the portafilter into the group ring. Pull the handle all the way to the right and hold. Turn espresso hot water switch on. Hold the portafilter pulled all the way to the right for 5 seconds (pre-infusion pressure builds up to 9 bars). Release the handle at the end of 5 seconds. Espresso shots should be max. 2-Oz. in the cup. For larger quantity, use two shots. For an Americano, add hot water instead of allowing 8-Oz. water to pump through the coffee grounds.
Mar 05, 2009 | Saeco Aroma - Stainless-Steel
Knocked out spent coffe grounds come out mushy not like a puck
Adjust the grind on the machine, or the amount of coffee the grinder puts into the chamber.
Jan 12, 2009 | Saeco VIA Venezia
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
