Question about Maytag EcoConserve Series MVWC360AW 27" Top-Load Washer with 3.6 cu. ft. Capacity, 11 Wash Cycles, 800 RPM Spin Speed, Energy Star Qualified, IntelliClean Impeller, Smooth Balance Suspension System and Deep Clean Option
Maytag centennial ecoconserve top load washer spins then refills and spins just stuck in this vicious cycle
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
beltronic205
  • 1467 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
heatman101
  • 43501 Answers
SOURCE: Atlantis MAV6000 Top Load Washer: Maytag Top Loading Model MAV6200AWW not spinning w...
Here is a tip that will help you with that...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 05, 2010
Can you adjust the water level if you want more water for your wash cycle?
it may be possible if the water level pressure sensor has an adjustment for the pressure setting
or you could simply select full wash each time
Jan 07, 2016 | Maytag Centennial EcoConserve Top Load...
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Some white spots on clothes at the end of wash cycle?
Not sure if you use bleach but you could have bleach spots if you do.
Mar 18, 2015 | Maytag Centennial EcoConserve Top Load...
Maytag centennial washer
Hello there and welcome to fixya
Here is the specifications on this washer
and this should explain why it dosent take much water to get clothes clean
This high-efficiency Centennial Top Load Washer features the IntelliFill automatic water level sensor and 11 automatic wash cycles to give you plenty of options. Low Water Wash with EcoConserve helps you save energy, while its spacious capacity means plenty of room for your largest loads. Inside, the stainless steel wash basket resists chips, scratches, and odors, as well as maintaining a smooth surface so it won't snag or pill fabrics. You get all that and still use 70 percent less water and energy in a model that pays for itself in four years. This no-nonsense machine does what you want.
  • CLICK HERE to learn more about Maytag Appliances
  • 3.6 cu. ft. capacity easily handles large loads and bulky items such as comforters
  • Rear panel controls provide convenient access to all cycle and option selections
  • IntelliClean impeller continuously moves clothes through the water for a thorough cleaning
  • 11 automatic wash cycles including heavy duty, casual, bulky and delicate to provide washing options to handle a variety of fabrics
  • ENERGY STAR qualified with a CEE Tier III rating: this washer is among the most efficient washers in the industry
  • Stainless steel wash basket resists chips and scratches and helps to protect fabrics from snags and pilling
  • Automatic Temperature Control monitors and adjusts incoming water flow to maintain the selected temperature for more consistent cleaning results
  • Low water wash with EcoConserve: use less water and get better cleaning performance through concentrated wash action, Low Water Wash technology enables the detergent to penetrate better and pre-treat soils with a concentrated mix
  • The IntelliFill sensor regulates the amount of water being used, making automatic adjustments based on the size of the load and type of fabric
  • MaxExtract Extended Spin option accelerates the load's final spin to remove moisture and reduce drying time
  • Deep Clean option uses a additional cleaning action and a deep rinse to ensure load is clean the first time
  • Click Here for details on the services included with Delivery & Basic Hook-up and Installation options for Major Appliances
  • MFG Model # : MVWC400XW
  • MFG Part # : MVWC400XW
May 25, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
My Maytag Centennial top load washer start to refill at the end of the spin cycle....help!
This is an issue with the timer starting the cycle over again and it will need to be replaced. Here is the part to order. To replace the timer remove the back of the console to access the timer.
Nov 23, 2012 | Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag EcoConserve Series MVWC360AW 27" Top-Load Washer with 3.6 cu. ft. Capacity, 11 Wash Cycles, 800 RPM Spin Speed, Energy Star Qualified, IntelliClean Impeller, Smooth Balance Suspension System and Deep Clean Option Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
