Question about DeLonghi EAM3200 Espresso & Coffee Maker
Delonghi magnifica flashing light does not tamp grounds
Beans grind then dump right into the bin without getting compressed and making an espresso. the bypass light flashes
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
mnwarfield10
  • 452 Answers
SOURCE: My machine will often (not
we repair ring 07779933829 uk
Posted on Jan 25, 2011
mnwarfield10
  • 452 Answers
SOURCE: Delonghi 3400, spend grounds going wrong place
we repair 07779933829
Posted on Jan 26, 2011
espressonist
  • 1711 Answers
SOURCE: I have a delonghi magnifica coff maker, when we
The grounds coffee funel is comunicate with the grinders out funel. So the coffee after it been grinded id moves to the coffee group brew and it actualy pass from the same pasage as grounded coffee entrance. So the funnel downward to the brewing group is blocked by something. Many times from grounded coffee which absorved humidity and become solid. Some other times from cleaning tablets which again stuck in the funel. So if you have a cleaning round brush of about 1 inch diameter or less you can insert from the ground coffee opening door downward so to clean the funel from anything. If their is too much grounded coffee you can insert first a srwedriver or the back of a spoon or similar rod tomake an opening first and then use the brush. After that you will have to remove also the brewing group and clean it well. Leave everything to dry out and test it, If the problem insist it may be a plastic part of the funel braked or moved out from position and this is what is blocking the coffee to go down. In this case you will have to remove the top panel to have a good visual inspection.
Posted on Jul 16, 2011
SOURCE: poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Posted on Mar 12, 2012
My Delonghi Magnifica 3400 is making weak espresso. Is it the diffuser?
Have a look how much coffee is actually thrown in by the machine. You can take a flash light and look down the ground coffee funnel, when the machine is grinding. Or after making a cup of espresso, look in the tray how much coffee it dumped in there. I don't think the infuser is the problem. I expect there's a problem with the grinder...
Oct 29, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi problems
Do you have dry coffee in the waist bin? do you have water coming ? I can offer you coffee but I can't give you because I don't have it
Aug 16, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Poured water in my delonghi magnifica beans hopper.
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My delight magnifica is now grinding too much coffee causing lots of excess falling into machine. How to I adjust the grinding time?
I had this same problem and discussed it with DeLonghi customer service. My machine was grinding 20 seconds for a double shot and ground coffee was coming out of the top and spilling over inside what a mess! DeLonghi thought it was potentially a problem with the control board - grinding time too long - which is an expensive repair. I also called the local factory-authorized service and described the same problem. They asked what kind of beans I was using and I answered Starbucks espresso. They said that Starbucks is too oily, clogs the machine, and that I should try beans that are lighter. I also checked with an engineer who used to work at Starbucks and he made the same guess. I tried an Italian roast espresso from a local market and it worked! I've had no problems since. The new beans cleaned out the oils and I'm getting great shots. This is a good machine, but is best making single shots.
Jun 11, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
I cleaned my delonghi magnifica and now nothing works. neither water or coffee comes out.it is just out of warranty unfortunately. help!
have u switch it on on back cover ??? ummm make sure u have the bucket sat in correctly .....and tray is in properly... have you snapped off the peg on the rear of the bucket for wast ?? its located rear of bucket. bsc appliances bristol 07779933829 postal service too.
Feb 08, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3200 Espresso & Coffee Maker Logo
35 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
