Question about Haier XQJ50-31 Top Load Washer
THE SPIN CYCLE IS BROKEN - Haier XQJ50-31 Top Load Washer
  • Dean James Stuart
    Dean James Stuart Mar 19, 2014
    the spin engine won't push through to proper spin, it starts revving then conks out. the load becomes unbalanced and doesn't dry properly
Machine won't shift from rinse to spin cycle
Your lid switch is broken.
Unplug the machine and check with your hand for broken pieces under the lid switch hole.
Replacing this can be really easy.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
My Roper washer will not spin on the spin cycle.
IF ITS A TOP LOADER YOU MAY HAVE A BROKEN LID SWITCH. LOOK DON THE HOLE IN THE TOP WHERE THE LID PIN GOES CAN YOU SEE THE LID SWITCH ARM? IF ITS NOT FLUSH WITH THE HOLE ITS BROKEN. SOMETIMES YOU CAN STICK SOMETHING THROUGH THE HOLE TO ACTIVATE IT
Jan 15, 2010 | Washing Machines
Clothes wet after rinse cycle
lift the washer on its side and see if it has a drive blet that broken for the spin cycle.
Sep 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle won't work
Drive belt is broken or clutch is broken.  If this is a top loader, turn it on its side and look underneath to check the belts.
Jun 02, 2009 | Kenmore Washing Machines
Whirlpool washer Loud Grinding sound in spin cycle
HI,YOU MIGHT HAVE EITHER A BROKEN SPIDER THAT IS LOCATED BETWEEN THE IN AND OUTER DRUM OR A BROKEN BEARIG.BEST YOU GET A EXPERT TO HAVE A LOOK AT IT FOR YOU.GOODLUCK.MOHAMED
Sep 10, 2008 | Washing Machines
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Oct 09, 2007 | Indesit W 123 Front Load Washer
Haier XQJ50-31 Top Load Washer Logo
32 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
