Question about Vacuums
Shop Vac on/off switch
Can the on/off switch be repaired or replaced on 3 Gallom Shop Vac All Around?
    Problem Solver:
  • 15 Answers
Yes, you need to remove head unit from canister and pull head unit apart, switches are usually common and are just push in. available from electronics suppliers
Posted on Mar 23, 2014
  • Jo Tate
    Jo Tate Mar 24, 2014
    Thank you. I will try it tomorrow.
Shop vac qps30 on off switch stays on Do I have to replace
It would be a good idea since the points inside the switch are welded together and produce heat.
Nov 09, 2017 | Shop Vac Vacuums
My 3.5 hp 8 gallon shop vac wont turn on. Fuse? Reset switch?
possible a start/run capacitor failure
take it to a vac shop for diagnosis and repair
Jan 08, 2017 | Shop Vac Vacuums
Our BLB500, 12 gallon, 5.0 peak HP, Shop Vac won't come on.
From what I have heard, the switch on these units can sometimes be defective. Also, looking closely at the the AC cord may help determine if there is damage to it that should be repaired.
Jan 08, 2016 | Shop Vac Vacuums
How to replace on-off switch
Modern vac motors are polarized and cannot be made to run backwards. Take it to your local vac repair shop and let a professional repair it for you.
Jan 08, 2015 | Hoover Vacuums
Shop-vac model 500A 52713-75
what is the problem ?
God bless you
if if suction, test the hose blockage 2) belt drive is worn 3) power brush dirty, clean or replace, 4) test the motor for repair, clean, and lube.
see the diagram
Sep 06, 2012 | Shop Vac Vacuums
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I have a shop vac. model 500x 1h.p. Center section speratedon impeller cost of new ? or throw away ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794495
Generic problem for all Vacuums
I have a shop vac.
Posted by mymino on Jul 17, 2008
I have a shop vac. model 500x 1h.p. Center section separation impeller cost of new? Or throw away?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are only 2 ways that I can think of in answer to your question. Either you can replace the fan impeller or you have to replace the entire motor. You would have to contact your local vacuum cleaner dealer in your area or contact the Shop Vac factory @ the website or to call the factory @ the phone 3 listed below; or check your owner’s manual.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Kenmore Progressive Bagless Upright with...
Vacuums Logo
262 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
