Question about Audiovox VE1020 10.2 in. TV/DVD Combo
Good picture, sound is only static
I have fairly good picture. Sound is only static.
  • Amy Kasprzak
    Amy Kasprzak Mar 19, 2014
    I fixed it. I unplugged TV for 10 minutes and plugged back in. Presto! Problem fixed!
  • Amy Kasprzak
    Add a Commentsaw this suggestion somewhere online. Thank you.
Emerson lc320em2 HAS A PICTURE FROM HDMI BUT NO SOUND IF I UNPLUG FROM CABLE BOX AND PLUG BACK IN SOUND COMES BACK ONCE I POWER OFF AND ON NO SOUND SOUND DOES WORK ON COAX CABLE
Chances are you have an issue with the main board. Those can be purchased on eBay for around $20.00. If you go the route of changing that board be sure to match the number of your board that is in the TV, don't search by model number as this model used several different boards and some are not interchangeable. One word of caution, use static precautions when handling the board, it should come in a static proof bag of wrapped in static bubble wrap ( generally pink in color) be at the set before unpacking the new board, just walking across carpet with it in your hand can damage a good board.Good luck!!
Oct 16, 2017 | Emerson Televison & Video
Good pictures but no sound just static
tvs get their picture and sound on different channels, and in europe, and in the usa the sound is on different channels, try in sound settings to set it to your area's sound defaults, so the tv will search for the sound at the right channels.
Apr 16, 2013 | RCA F36450 36" TV
No picture, medium gray screen, sound volume will go up and down, but no "sound" just static.
Hey!
Dude there is a problem with the ( TV turner card ) some component is being over heated or has leak this card should be changed .
This card feeds the TFT with the voltage needed to glow and picture, sound, so should be checked.
Good luck
Nov 30, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Sound off
you are having problem on your tv with your tv sound ic this can be located ion the sound circuit just where the speaker is hooked up inside the set if you are not a tech have one repair your tv good luck
Jul 12, 2009 | Televison & Video
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
No picture
Good Day;
Try resetting the TV by unplugging from the wall A/C outlet for 3 to 5 minutes, plug back in. No fix? Your TV's LAMP needs to be replaced. Part number; UX21516, for Model 55VG825.
Good Luck, big IRISH.
Jul 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
2003 PT-47WXD63G...NO Sound/NO Picture
by pss your sat. to see if audio returns if so ck. settings on sat, box.
Mar 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PLTV-32 GOOD PICTURE, Static Sound
If it is under warranty, you would be better off the return it for an exchange as the main board will need to be replaced. this board is not cheap. Good Luck
Mar 21, 2007 | Protron PLTV-32 Television
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
