Question about Garden
Clutch spring need to know where the clutch spring is located on a model # 160+370738
    Guru:
  • 145 Answers
Which spring? The BIG one?? This is a really really old tractor right?
Posted on Apr 12, 2014
Where is the spring to my clutch pedal located on my 2000 kia sephia
If we're talking about the same spring, its located inside the transmission. The cable is usually adjustable or sometime stretch. I don't know the problem.
Feb 15, 2017 | Kia Cars & Trucks
What is torque setting for clutch springs?
Hi Mick:
Don't know what your bike is so suggest you refer to you make and model service manual.
Example - My KLR 650
Clutch hub nut - 100 ft-lb
Clutch spring bolts - 87 in-lb
Oct 18, 2015 | Motorcycles
I NEED THE LOCATION TO ATTACH THE PTO CLUTCH SPRING.
need to know what mower exactly
Jul 29, 2015 | Garden
The clutch return spring broke on my lawn tractor model 917.272242 and i cannot see at what points it connects my diagram is not a real .can you help
If you go to searsparts.com and put in your model number they will have a diagram as to how the spring attaches.
Jun 20, 2014 | Craftsman Lawn Mower
Hi. I have a 98 ST2 and just replaced the standard clutch springs with aftermarket. Tensioned them to 5 lb ft and the clutch won't go into gear. Just spins as if it still in neutral.
Is the clutch working correctly are the plates compressed. Without operating the clutch lever the clutch should be fully lock the center hub to the outside cage. Does the clutch front plate move when you squeeze the lever? If not I would suggest the springs are: - a) too long, b) not correct for your model or c) have too much tension in them and so holding the clutch open. I know they cost more but I would get OEM springs.
Hope this helps
Apr 07, 2014 | Ducati Motorcycles
Cycle clutch spring broke on selectric typewriter
I am a former IBM customer engineer. I have replaced thousands of cycle clutch springs in the 80's. IBM was known for supporting the typewriters by manufacturing parts twice to three times as long as other companies. Call their parts department. I purchased third party parts from AMES and Tech Support. Both companies were located in Atlanta Georgia. Those two companies also sold the tools that are needed to replace the part. Then you need a tech. Cycle clutches are not easy to replace.
Jan 31, 2012 | Lexmark IBM Selectric 3 Typewriters...
I have a Craftsman lawn tractor model 917.288030. When you turn key to start nothing happens. Battery is ok. I have replaced ign switch. I have swaped selenoid with known good one. I have swaped out impact...
Hi and welcome to FixYa. I am Kelly.
Here are the 3 safety switches.
Seat
Clutch Brake
and PTO Clutch
More ofthen than not the PTO Clutch gets a gap greater than 0.020 between the clutch and the clutch plate and the safety switch is not made. There are 3 bolts with springs and 3 slots in the PTO clutch. Adjust the tension on the springs until the gap is 0.020. Then try a start.
If it does not work:
Check out this diagram.. it is for your mower:
http://c.searspartsdirect.com/lis_png/PLDM/P0905008-00011.png
I found your particular model here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00011?blt=06&prst=0&shdMod=917288030
Parts can be located by choosing the diagrams under the small schematic. I think if you adjust the clutch you will be fine. The seat has to be occupied / switch shorted and the clutch brake pedal made to get power to the solenoid.
Respond ehre is you need more help.... Better yet let me know if the PTO clutch adjustment corrected the problem.
Thanks for choosing FixYa,
Kelly
Jun 05, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Im a person that know just about nothing about cars, but i need to know where the clutch is in my kia rio ls 2005 model. im not 100% sure whats wrong with it but when i accelerate the clutch seems to...
Your clutch is located inside the semi rounded housing that is sandwiched between the back of the engine and the transmission. It's a big job to get to it and best left to someone with experience. As for the throttle, make sure there is a return spring on the linkage on the throttle body where the throttle cable attaches to it. It may have broken or fallen off. (find that by having someone work the gas pedal and look at what moves on the engine when you do that.)
May 27, 2011 | Kia Rio Cars & Trucks
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
Clutch is slipping is there an adjustment? 1997 royal star
Yamaha has a curved washer style clutch spring that it uses for this model. These have been prone to slipping from day 1. Normally when you get on the throttle hot and heavy. A new spring will help the situation for a while but you may have to replace the clutch pack to get more pressure through out the clutch pack if the bike has high miles on it. Maybe the dealer would know if the VMAX spring is heavier and would work as a replacement.
Apr 25, 2010 | 1997 Yamaha Royal Star XVZ 1300 A
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
