Question about Samsung Galaxy Rush Boost Mobile
I entered 1 number off from my number lock passlock i would like to reset the phone
Please master reset my phone
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Posted on Jul 04, 2014
Iv forgotten my security code and would like the master code to reset my phone,can you please help me
check your imei code via *#06# or check in behind the battery, and write
down the code (the numbers
have 15 digits) then you enter
the address trikgratis.com/mastercode/ and input your imei code and then click
generate and record the nokia
master code, then you go to settings> security> change the
security code phone> then enter
the master code nokia then
press ok and you will be asked
to enter a new password
Sep 06, 2011 | Cell Phones
Forgot my phone lock
the only way out of this is , you have reset your phone, try getting reset codes from http://www.unlocking4u.com/ to master reset your phone back to
normal
Jul 14, 2011 | Cell Phones
I HAVE A BOOST MOTOROA BT50 CELL PHONE AND I NEED TO FIND OUT HOW TO MASTER RESET IT CAN ANY ONE HELP?
Doing a master reset on ANY phone is a last resort in fixing any problems with your phone. Unless you have a memory card to store all your info on, u may lose everything on your phone, including contacts, pics, and bookmarks. Before you consider doing a master reset, contact the Boost Mobile service provider. Boost Mobile uses the Sprint network, so maybe contacting them is a good place to start. And if they suggest doing a master reset, they will tell you how to perform this action. Before you do, write down all the personal info you have saved on your phone!
Jul 09, 2011 | Motorola Mobility Boost Mobile...
Phone lock code
assuming that you have forgotten your Phone lock code, one way to solve this is by master reseting your phone, first you have'nt mentioned your phone Model?? in case if it is a Nokia phone try reseting it using master reset codes from to bring it back to normal http://www.theunlockarena.com/
May 28, 2011 | Cameras
Went to "master reset", entered
Please get the PUK ( phone unlock key) on service provider . Unlike PIN using 4 digits code, the PUK using 8 digits.
Feb 04, 2011 | Cell Phones
My nokia 6233 has a problem, he say "security code" please help me!
1. Go to the site http://unlockme.co.uk and enter your phone's IMIE number and press Enter then u'll get the master code of your phone.
2. This master code can be used as lock code when we are asked for the security code.
3.But always we can't remember master code and we want to use an easier lock-code then we can set a new security code of our own wish by giving the Master-code as our old security code when asked for old code while resetting security code.
e.g.NOKIA 6600
Tools -> Settings ->(scroll down) security -> Phone and SIM ->(scroll down) Lock Code
Then it asks for old code where u can type the master code and then set the new code as you wish.
When during formatting u are asked for lock code you can also enter Master code.
Thanks for rating
Good luck
Jan 16, 2011 | Cell Phones
Crack nokia 3110c sequrity code
1. Go to the site http://unlockme.co.uk and enter your phone’s IMIE number and press Enter then u’ll get the master code of your phone.
3.But always we can’t remember master code and we want to use an easier lock-code then we can set a new security code of our own wish by giving the Master-code as our old security code when asked for old code while resetting security code.
e.g.NOKIA 6600
Jul 13, 2009 | Nokia 3110 Cellular Phone
Sony Ericsson M600i Master Reset Code
Please help, I flushed my phone's GDFS file to my friend's M600i and it seems locked phone code and can not boot this phone. Do help me to get Master Reset key, the phone's information : IMEI:35931500-401250-5. thks !
May 10, 2008 | Sony Ericsson M600i Cellular Phone
Resetting Security Code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 13, 2008 | Nokia 3110 Cellular Phone
hi freinds
i have nokia 1100 phone ane my imei is 35793000/200543/4 and i had for got my security code can some one help me to reset it and can you help to reset code for nokia 1100 phone
Oct 02, 2007 | Nokia 1100
Samsung Galaxy Rush Boost Mobile Logo
41 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
