Question about Prestige Appliances Microwave Ovens
Do not know what com1 com2 and adj is on microwave prestige pm800g
Adj does not seem to do anything com means compartment i suppose
2 Suggested Answers
SOURCE: PRESTIGE CB130
On Prestige Combi Microwave the bub is on the control panel side. First remove the cover, Philips and torx required to remove screws on the back. *** MAKE SURE MAINS PLUG PULLED OUT ***
Looking at at the magnetron unit, find a black oval shape between it and the control panel with two wires plugged in, there are two bend strips holding the bulb holder in (this is directly behind the vent holes on the right hand side of the microwave oven), straighten them and extract holder with bulb, swap bulb with same rating and reverse the operation and re-assemble.
Posted on Dec 31, 2009
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Apr 28, 2013 | Microwave Ovens
Silver card has come off on the inside right,is the microwave safe to use .its a prestige model dse20
this is the waveguide cover it covers the anoide of the magnetron,its not really a good idea to use the unit without it as it does two things it allows the microwaves to pass through it but stop anything from getting onto the magnetron if you know of anywhere that repairs microwaves they may if you take your old cover to they might be able to cut a replacement of if its just fallen out you should be able to slot it back in the corners just sit in the slots in the side panel hope this helps
Dec 09, 2012 | Microwave Ovens
How do you set clock on prestige microwave model sde23r
how to set time on prestige microwave sde 23r
Jul 02, 2012 | Microwave Ovens
Microwave has intermittment power. Will start sometimes. Othertimes not at all. Any idea what the problem could be?
Chek for loose connection in the microwave electrical compartment Make sure your key pad working okay first Thanks Please rate me
Aug 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwaves
Sorry, but from your post, could you please clarify what is meant by these several numbers and which is the actual model number:
- CB125
- KES
- AUT
- 3AA
- 150701678
I'm not sure at this point whether you're talking about some brand that's called Prestige or a Panasonic brand line which is called Prestige.
But either way, we'd be happy to help if we can know which specific brand and model number you have.
Nov 23, 2007 | Microwave Ovens
Microwave Ovens Logo
Top Prestige Appliances Microwave Ovens Experts
William Miller
William Miller
Are you a Prestige Appliances Microwave Oven Expert? Answer questions, earn points and help others
