Question about GE Spacemaker JVM1640SJ Microwave Oven
How do I replace fuse of kenmore model 72189940490 microwave
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Mar 31, 2010 | Kenmore 80012 Microwave Oven
I need bulb number for 125v/30w night light kenmore microwave 72189940490
You should be able to match up your old one to a generic replacement at a place like Lowe's, Home Depot, etc.
If not, see this link. Look those part numbers up there and here.
Your owner's manual is here.
Jan 14, 2010 | Kenmore Microwave Ovens
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
Microwave electrical problem
Unplug, take all the screws out from around the case. Remove case. There is a fuse inside (Without Model number I can't tell you right where it's located) It looks like one of the old round car fuses only it's white colored. It's made of ceramic. Replace it and put unit back together. This is a common problem when one does what you are saying yours is. Be thankful that's all, if you had anything working it would be something major and would be cheaper to replace unit if it a counter top model.
  • NOTE: DO NOT REPLACE WITH CAR FUSE. USE ONLY MICRO WAVE FUSE.
Please rate solution
Sep 05, 2009 | Kenmore Microwave Ovens
Kenmore elite mircowave model 721,62369201...has a F9 error. ?? The unit runs, but does not heat up.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 19, 2009 | Kenmore 63792 Microwave Oven
Kenmore microwave model 721-63252301 - no heat turns on - but nothing is getting hot
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Jun 05, 2009 | Kenmore 63252 Microwave Oven
The fuse keep burned every day I do replace the fuse, what is the wrong with my Kenmore micrwave 565.61589011 model. Thank you
Chances are that you have a common connection with another plug. Microwave, Fridge etc.. Even if it's not the same plug it's still "In line" meaning that both outlets are on the same breaker. A: Find another outlet to plug your Microwave into or B: Put a surge protector in between the Microwave and the outlet.
Mar 10, 2009 | Kenmore Microwave Ovens
All lights went out and no buttons will work.
the protection circuit has operated, this is not uncommon on microwaves. the fuse is inside the unit and therefore require dismantling. replace fuse and all should be fine, if it blows again then you have a more serious problems
Feb 18, 2009 | Kenmore 80412 Microwave Oven
Thermal fuse
You can usually find an exploded view and order parts by entering your full model number here: http://www3.sears.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 11, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
52 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
