Question about Magellan RoadMate 5220-LM GPS Vehicle Navigation System
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
My Magellan started turning off unexpectedly while in route. After a while after I plugged back in the screen would not go past the first screen with Magellan logo and the clock. I have downloaded the newest software and screen worked fine while doing that. But again tried to hook up in the car and it would not go past the first screen. Also the slot where the charger plugs in at seems to be loose and moves around a lot. Charging light does not stay on consistently when plugged in to computer or car charger.
    Sergeant:
  • 333 Answers
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Posted on Mar 18, 2014
2 Suggested Answers
  • 5 Answers
SOURCE: My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
Posted on May 16, 2010
How do I set my destination
If you do not have a manual you can view one here.
Chapter 5 SELECTING A DESTINATION starts on page 13
Jul 19, 2014 | Magellan's RoadMate 5220-LM 5" Touchscreen...
How to make Hardware reset of Magellan Roadmate 3055-MU?
need help hard resting minemagllan roadmate 3045-lm gps
Jun 07, 2012 | Magellan Roadmate 3055 GPS Device
Register Magellan RoadMate
Hello.
If you want to register your Magellan, You need to go to Megellan web site and create password.
Here is the link to copy and paste in your browser. http://www.magellangps.com/s.nl/sc.73/.f?login=T
Sep 29, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
How to set up Magellan Roadmate to Bus mode
If your unit is equipt for this feature, then here is the operation manual link to copy and paste and put in your browser to help you.
http://www.manualbuddy.com/1598/magellan-roadmate-5045-manual
Thanks Mike
Sep 22, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
How to set up Magellan Roadmate 5045-LM to pedetrian mode
You have to go to settings to do this. Another easy way is punch in any address and before you actually except it, look up in left corner and will give you option of shortest distance, fastest distance and pedestrian mode. Also if still having problems. Here is a link to copy and paste in your browser and will help you. http://www.magellangps.com/ Thanks Mike
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
Turns On but not past the loading screen
Hello :
I recommend you to reset your RoadMate .
To reset your RoadMate please follow these steps :
1: Locate the button marked "Reset" on the left, right or bottom of the unit.
2: Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
NOTE : Please don't attempt to perform a factory reset on the Roadmate or Maestro GPS units by holding down both the "Reset" and "Power" buttons. This will cause the GPS unit to format its own hard drive. Doing so will erase all data, including the GPS software, from the unit.
This solution should help with your problem . If that didn't help , then I recommend you call Magellan service for help .
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Magellan RoadMate 1340 GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan RoadMate 5220-LM GPS Vehicle Navigation System Logo
392 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
