Question about Motorcraft 2006 WLRA-4 Ford F150 Truck Window Regulator Power with
What color are the wires on the wire harness for the throttle body sensor plug
Some plugs were cut off wireing harness need to know the color of wires that go plug for the throttle body sensor
2 Suggested Answers
  • 1249 Answers
SOURCE: how do i know which are speaker wires i put power to all of the wires coming out of the 16 wire plug and still no sound
I suspect you have a factory amplifier somewhere. Now would be a good time to find a tech.
Posted on Dec 14, 2014
Wiring pigtail input speed sensor on my 2000 sonata. The new plug came with three white wires but the wires from car are different colors. color wiring diagram ?
the connector is the same on both the old harness and the new pigtail. As long as you orientate the connectors the same way you just match up the wires. let me try to explain it this way. If you hold the old connector so the part that holds the connector to the sensor is facing up. Hold the new connector exactly the same way. cut the left wire on both and connect the new connector wire to the old wiring harness. Then cut the center wire and connect them. then cut the right wire and connect. No wiring diagram needed.
One thing I will add is to stagger the new connections. Meaning do nut cut them at the place. Cut one wire then cut the next about an inch or so further and then cut the next about an inch or so further than that. This will prevent the new connections from potentially shorting to each other and will keep the harness from becoming really bulky with all the but connectors in the same location.
Oct 02, 2015 | Cars & Trucks
2003 Montero Sport 3.0L, 135K miles. Cold start, idle ok. Once warm, low idle and sounds like it has a miss.
Your going to need a wiring diagram. You have a MAF,MAP, IAT and EGR sensor problem. My guess would be a signal wire or ground is bad. These four sensors are right at the throttle body. The mass air flow sensor and the manifold absolute pressure sensor are one in the same. The intake air sensor is next to it. All are located in the air induction plenum. Between the throttle body and the air filter. The Engine gas recirculation valve/sensor is right behind the throttle body. So check the harness from the air filter/ MAF to the engine harness plug. Look for conduit that is rotted away and/or melted.
Feb 25, 2015 | 2003 Mitsubishi Montero Sport
Color codes for stereo
They make kits just for this. Just plugs into the existing harness and then you run you wires to the wires from that harness, some may even have matching plugs that go directly to the Head units wire harness plug. I did My Mustang by cutting into the wire Harness and simply used a multimeter to check for battery, memory 12 volts and running light or dash board Illumination wires then you can test the wires coming out from the stock radio to see which are right, left , front, rear, antenna out, etc..
I just labeled them with magic marker on some masking tape with what they were before I cut off the harness permanently.
Jan 23, 2014 | 1999 Ford Contour
Idle switch sensor
It plugs into the air filter intake hose on the driver's side.
Apr 20, 2017 | 1988 Nissan 300ZX
Oxygen sensor broken wire
The main issue is the heat from the exhaust system. What ever wire you use needs to be insulated with some silicone heat tubing.
Aug 18, 2017 | Toyota Corolla Cars & Trucks
My boyfriend is trying to install a cd player in my '94 cougar and there's this big grey wire thats taped up with the smaller colored wires. he dicided to cut the little plug thng off of the grey wire and...
Generally, the way I put an aftermarket cd-player in, is to use a new 'harness adapter' that connects to the old harness and has all of the wires color coded and labeled for easy installation of a new radio using wire nuts. I wouldn't try to cut into the existing harness, without knowing what was what.
What's the 'little plug thing' off of the grey wire?
Aug 07, 2010 | 1994 Mercury Cougar
Half power
check the throttle position sensor.or any oil getting leaked from the throttle body.if its leaking then the oil needs to be cleaned from the throttle body. check out.keep updated.thanks.
Feb 28, 2010 | 1997 Jeep Wrangler
Motorcraft 2006 WLRA-4 Ford F150 Truck Window Regulator Power with Logo
Top Motorcraft Scuba Diving & Snorkeling Experts
Jesse Garza
jeff5may32
bobalix
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
