Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
What is the white handle for - Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
I have the Ninja Kitchen System 1100 and the only way I've found to lower the handle on the lid is to simultaneously depress the two white "tabs" at the base of the handle. This is awkward at bes
Make sure you have the arrow on the handle in alignment with the arrow on the lid. Press down securely before closing the handle.
Jan 16, 2013 | Vacuums
The white plastic(?) full length door handles OUTSIDE the refrig are turning yellow on my white, side by side refrig. What can I purchase or use to re-whiten them and make them look clean and white again?
That yellow coloring is most likely a result of the white paint coming off, and the yellow plastic color showing underneath. Other than painting them with a good paint, which you would have to ask a paint expert for the proper type, my suggestion is to replace the handles altogether.
Oct 13, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
Handle on fridge side is loose
Look at the top and bottom of the handle. There should be a plastic end cap you can gently pry off exposing the screws to remove and tighten the handle.
Oct 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a 99 mitsubishi eclipse and I'm wondering how to install the door handle
i just did one on passenger door, roll window up, use 1/4" sockets, on door end, by door latch there is a 10mm, level with door handle, take off door panel inside, you'll see the window where its bolted, just behind that dip down shape of the window where it attaches, you'll see another 10mm bolt, take those 2 bolts out, remove the two extension rods, cliped on to handle lever, and lock cylinder, one on handle is white clip, one on cylinder is green clip, flip the snap part of clip away from rod, and slide rod out of clip hole, walla, pull handle out, unclip retainer clip from around slots holding cylinder into handle, and your done, p.s. try to reclip door handle rod into white clip before bolting back in to gain easier access to white clip and rod, green isnt as hard
Jun 30, 2009 | 1999 Mitsubishi Eclipse
Plastic handle Rival slow cooker model 38511 broken
The problem is the threads strip on the bolt and nut. I took these to Home Depot's specialty fastener section (the one with the drawers of stuff) and purchased a nylon bolt and nylon wing nut and solved the problem. I is easy to remove for cleaning and all is dishwasher safe.
Apr 03, 2009 | Crock Pots & Slow Cookers
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
