Question about Panasonic PV-C2061 20 in. TV/VCR Combo
My Panasonic 27" Omnivision TV set (PV_C2542) flickers intermittently until I jiggle the cable conection into a new position. Sometimes the TV image goes off entirely and appears as a blue screen. Sometimes it works fine for a few hours. The cable connection itself is not loose but the whole metal box it goes into is slightly loose on the circuit board that connects to it. The VCR mode works ok as far as I can tell. The flickering started before the national change over to HDTV. A few months ago my cable company changed to accept either my old plain TV or the new HDTV. My two old TV sets had no problems with the transition. Is there any way to fix my old Panasonic TV? Thanks
  • 749 Answers
Your tv set need parts Resoldering.
intermittent color changing is cause by cold solder joints.
have it serviced by a reliable electronic repair center or person.
you should not be charge a lot.
if you wish to fix it yourself,
you need a Soldering Iron (about 60watts) and soldering Lead (60/40).
air blower (for fast Cleaning) or
[1inch paint brush (for cleaning)]
unplug and place your set to your work bench then open the back cover.
(since you say its old, expect lots of dirt/dust inside your set, use the blower for easy cleaning).
if you have completely access of the solder side of the circuit, just resolder the joints. BE CAREFUL... DO NOT CONNECT SEPARATE JOINTS.
if you don't have experience with electronics i advise you have it to a repair person.
hope this helps you!
Posted on Jun 14, 2009
VOLUME STUCK
you use auxilry port in your tv as volume problem volume out from direct TV cable bos insert in tv auxilry port
May 17, 2012 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Picture on my Panasonic PV-DF2700 flickers and then there's a blue screen. Cable company says signal is going to TV. Is the TV history?
Hello, the tuner could be ready to go out entirely, but you can still view your cable TV through your Auxiliary input jacks(video/audio colored jacks) most of the cable boxes ave these outputs in the rear all you need is the RCA cable(yellow/red/white) and select the video input you want to use. The other solution is to replace the tuner. You can order one through www.partstore.com or directly from panasonic at their website www.panasonic.com.
Nov 26, 2010 | Panasonic PV-DF2700 27 in. TV/VCR/DVD...
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Televison & Video
Panasonic omnivision PV-V4021
Read the book. ........... Get one.
Apr 17, 2008 | Panasonic PV-V4021 S-VHS VCR
Flickering image
I have a vcr and dvr combination emerson tv a 27 inch and sometimes while playing it will flicker and these horzion lines come in while a program is runing, and then the sound goes way down then comes back up to normal.
can you give me a answer?
Is it my picture tube it is about to go out?
It is close to five years old
Feb 23, 2008 | Emerson EWF2703 27" TV
Recording VHS from TV/VCR combo onto DVD
This machine does not support DVD recording. Are you trying to make a tape from a DVD, by some chance?...accordianman
Jan 21, 2008 | Panasonic DMRES15 DVD Recorder
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Loss of picture and sound repeatedly
You already hit the nail in the head,the problem might be the actual conector loose inside the set or the tuner has loose conections to the main board,the shell of the tuner is the ground make sure the conections are solid,if you are familiar with tv service this will help but if you are not too familiar be safe and call for help,right now it should not be expensive.
Oct 04, 2006 | Panasonic PV-C1321 13 in. TV/VCR Combo
Panasonic PV-C2061 20 in. TV/VCR Combo Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
