Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush is not turning after a loud noise and burning smell
  • Official Brand Answer
  • 2,572 Answers
Hi Laura, it's Jack at Dyson.
I'm sorry to hear you've had difficulty with your Dyson vacuum's brush bar. If the machine has made a burning smell, please do not continue to use your vacuum.
We'd like to take some further details, and will be able to confirm if a repair or replacement part is covered under our 5-year warranty.
You can reach our experts directly by calling on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to hearing from you.
Posted on Mar 18, 2014
  • Barney Tuorc
    Barney Tuorc Mar 18, 2014
    This usually means you have something stuck in the brush. I'd take the brush off and thoroughly clean it. I'd also check all other connections for clogs. Then try to restart it. They do have really good customer service if this doesn't work...just call.
  • Barney Tuorc
    This usually means the brush is clogged. Take it apart and clean it completely. I'd also check for clogs in other hose parts. If this doesn't fix it, they do have really good customer support.
3 Suggested Answers
ThinkVacuums
  • 144 Answers
SOURCE: my dyson dc14 is making a very loud noise along
your clutch is shot. It's an expensive repair.
Posted on Sep 01, 2009
SmartAlec
  • 171 Answers
SOURCE: Burning smell loud grinding noise when tilted
Hi there SmartAlec from NelsonVacuums.com.au here. The rattle is the clutch engaging. It can happen for a couple of reasons. The best case for you is if there is something caught in the brush roller that you can simply remove. The next best is that the end caps of the brush are full of junk that you will be able to remove. Its not easy getting the brush out to clean there but it can be done.
If the brush spins in your hand easily when the brush is removed then it is the clutch itself. THe main roller often melts which is caused when the tension on the belt gets to high thus creating too much heat. THis can be resolved only with a new clutch.
Hope this helps, if you have more questions dont hesitate to reply or if you need parts just visit
NelsonVacuums.com.au.
Happy Vacuuming :)
Posted on Apr 12, 2010
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Happy Vacuuming :)
Apr 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Extremely loud and smells like rubber burning
the loud will be the line is clog up and need to unclog the line, rubber burning will be the belt, which is worn or the brush is jam not allowing the brush to spin freely. check and clean the line and inspect th belt which run from the motor to the brush
Nov 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Our vacuum smells like burning rubber. Does it
Burning rubber smell means the brush belt need attention. Make sure the brush is turning freely and replace the belt
Jul 05, 2009 | Eureka Vacuums
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
83 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
