Question about Canon Cameras
Camera powershot a720 is doesn't reconise memory card
Going on vacation and the camera doesn't work.I think I messed up the camera by trying to program the details. Now it doesn't reconise any memory card [says no memory card]. My book is lost so I can't look it up. Hope you can help!
Judi
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Send in your camera to be repaired, this can be caused by many things, this is the easiest way
Posted on Jun 14, 2009
How do I save the photospn my Canon Powershot A720 IS to a memory card?
If you want to copy from memory card to another you'll need to do this in your computer, copy from card 1 and paste to card 2.
Oct 30, 2016 | Canon PowerShot A720 IS Digital Camera
16GB Transcend Card Locked
The S2 works with SD cards. Your 16GB card is an SDHC card and will only work in devices (like the A720) that have been designed to work with them. For the S2, you need to use SD cards 2GB and smaller.
Oct 01, 2012 | Cameras
I am unable to copy photos from my powershot A720 using data cable. pls help in transfering the data to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 24, 2011 | Canon PowerShot A720 IS Digital Camera
I have a canon A590 it always says the memory card is locked. Please Help we are going on vaction....
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If that doesn't work, try another card.
BTW, if you're about to go on vacation, get a second memory card anyway. Would you drive a car without a spare tire in the trunk?
Apr 17, 2011 | Canon PowerShot A590 IS Digital Camera
My Canon PowerShot A720 IS will not take a photo, when I press the button, nothing happens. I've tried taking the battery out and putting them back in and that seemed to help for a while, but now nothing...
Things to check first for a camera that won't turn on are battery contact points (in your case, based on your statement of the battery removal, recommend spending some extra time inspecting the battery contact points of the camera), and micro switches that are located on the battery door and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jan 09, 2011 | Canon PowerShot A720 IS Digital Camera
I plugged my Canon PowerShot A720 Is into my computer via USB cable and the pictures will not upload
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Nov 28, 2010 | Canon PowerShot A720 IS Digital Camera
Get memory card error
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Sep 06, 2010 | Canon PowerShot A720 IS Digital Camera
My memory card is locked. How do I unlock it?
Some memory cards have a tiny switch on the side of the card that is used to lock the card. Pull the card out and ensure the switch is in the unlocked position.
Jan 26, 2010 | Canon PowerShot A720 IS Digital Camera
As soon as I plug in my Canon Powershot A720, the
Buy an inexpensive card reader to download your pictures to a folder you create on your desktop.
Oct 20, 2009 | Canon PowerShot A720 IS Digital Camera
Memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
