Question about Ssl SD717MB Bluetooth Enabled Multi-Media Receiver 7 Flip-Out
Sd717mb ssl screen deck wiring harness
Need a wiring diagram
How do you hook up a bt39u radio
get a wiring harness from an auto store they usually have one for every car manufacturer and for sony decks they need to be converted from they're own pins to the standard audio deck wiring harness and if not most cars have little tags on the wires telling you what they are, red = 12v constant yellow= 12v switched green = earth black = earth and all the other colours are usually speakers and blue will be remote switched hope that helps
Apr 04, 2013 | Sony Xplod Mex-bt39uw Blue Tooth Auto...
I took out the stock deck and know have all sorts of electrical isuses i need to know what wires i 'HAVE' to have hooked up
U should buy a wire harness for the year of the car and follow the diagram then conect to ur new deck
Sep 21, 2012 | 1985 Cadillac Eldorado
I have 97 for ranger with tape deck with cd player
This should help you wire up your new stereo. 97 Ranger stereo wiring diagram. They do make a plug in harness for your truck. Metra part number 70-5600.
May 10, 2010 | 1997 Ford Ranger SuperCab
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
I need help wiring a kenwood cd player into a 1991 ford explorer
Here is a link for your explorer
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
and there should be a diagram on the back of the kenwood deck which would explain the deck side. if not your main power should be yellow = Constant 12V for clock
Red = Ignition 12V switch turn on the deck
Black = Ground
blue purple green white= for speakers
solid color = to positive on speakers
color with black stripe = negative on speakers
I would solder and heatshrink all connections Good luck
Oct 27, 2009 | 1991 Ford Explorer
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Wiring diagram
First, you can buy a harness for whatever vehicle you're putting it into and the colors on THAT harness will match the harness on the radio.. With that said:
black---------ground
red------------12V Switched (ignition)
Yellow-------12V (constant)
blue-----------power antenna
blue/white--Amp turn on
orange-------dimmer
white--------Left front+
white/blk---Left Front -
Gray---------Rt Front+
Gray/blk----Rt front-
green--------left rear+
green/blk---left rear-
purple--------rt rear+
purple/blk---rt rear -
Aug 04, 2008 | Sony CDX-M610 CD Player
Ssl SD717MB Bluetooth Enabled Multi-Media Receiver 7 Flip-Out Logo
23 people viewed this question
Top Ssl Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Ssl Audio Player and Recorder Expert? Answer questions, earn points and help others
