Question about Dell Photo 926 All-in-One Printer
Dell ink cartridges from Staples inferior to Dell? Just installed new Color, and message said to remove cellophane strip which I had done and matched with one removed. They were the same on back. T
Do all numbers & letters on back of cartridge have to match exactly?
  • Barbara Renick
    Barbara Renick Mar 18, 2014
    My Dell Photo 926 printer comments read "Low Ink" even after I installed a new Dell 9XL Series 9 color cartridge.
  • 628 Answers
As long as the manufacturer says that they are compatible, you should have no problems. As inks may vary from one batch to another, you may notice image quality issues, but as far as numbers go, it's enough that it is certified to be compatible with that type of printer..
Posted on Mar 18, 2014
SOURCE: Dell 962
Just found this partial fix: "Try removing the color cartridge and try printing with the color cartridge out. If it gives you a message that the cartridge is missing, it will still allow you to print by clicking "continue". And from there, it will allow you to print black. I think it really is a problem with your color cartridge." From searching the net, this seems to be a major problem with no solution from Dell!
Posted on Feb 28, 2007
SOURCE: dell 944 photo all in one printer
Set printer to print multiple copies. Put in less amount of paper. While printer is waiting for more paper, change cartridge.
Posted on Dec 04, 2008
SOURCE: Dell 924 printer problem with black cartridge
the printers are set to do this so you will buy there own brand but there is a way to reset the printer so it will work, I"m not exactly sure how, I'm trying to find that out myself. if you ask at the place that refills your cartridges they might be able to tell you
Posted on Jan 08, 2009
SOURCE: just installed new cartridges. won't align
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Posted on Dec 14, 2009
  • 20 Answers
SOURCE: New cartridge installed printer gives message that
Check both cartridges, one might still have plastic film that needs removal.
Posted on Dec 17, 2009
My printer doesnt make any print at all.
Can you copy a document under the glass? B&W and color?
Are you using Dell Series 5 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Aug 14, 2011 | Dell 924 All-in-One InkJet Printer
I keep getting a cartridge error message. I have replace the ink cartridges but still have the error.
Are you using Dell Series 11 ink cartridges?
Open the printer with the power on and remove the Dell Series 11 black ink cartridge and make sure the tape is off the cartridge, then reseat the cartridge back in. Now do the same for the Dell Series 11 color cartridge. Now when you close the printer, it should print an alignment page. Any error messages?
Black = Black side(left side) Color = Color side(right side)
Photo = Black side(left side) Color = Color side(right side)
Dell Series 11 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 11 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It possible to get a Dell Series 11 Cartridge with a bad sensor. Take back to place of purchase for a replacement.
Rick
Jun 15, 2011 | Dell 948 All-In-One InkJet Printer
My dell v313w printer gives the message that I need to replace cartridges even after I have put in new cartridges
Are you using Dell Series 21,22 ink cartridges?
Try Cleaning the Printhead on Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
Troubleshooting Printhead Problems on the Dell AIO V313w, V515w, V715w, P513w, and P713W Printers
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Open the printer(with the power on) and take out the Dell Series 21, 22 black cartridge and then reseat it. I would then take out the color Dell Series 21, 22 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 21, 22 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 21. 22 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 21, 22 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement or a refund.
Rick
Apr 19, 2011 | Dell V313w AllInOne InkJet Printer
Black cartridge is new. registers low ink level and does not print at all.
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Mar 17, 2011 | Dell 962 Photo All-In-One InkJet Printer
I am getting the following error message: Black/photo cartridge missing
Rick
Mar 06, 2011 | Dell 924 All-in-One InkJet Printer
I intalled new ink on my computer and it says to remove tape from cartridge when I all ready did and it will not work
Rick
Jan 10, 2011 | Dell 962 Photo All-In-One InkJet Printer
The colour ink cartridge is not being identified. I have tried taking them out and putting them in again. I have powered it off and on but nothing is working. Any suggestions would be greatly appreciated
Rick
Jan 09, 2011 | Dell 924 All-in-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
41 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
