Question about Check Point VPN-1 Accelerator Card Cryptographic Accelerator
Login errors occur when trying to use new networks
Check point vpn-1 secureclient login errors occur when trying to use new networks to connect
Log in errors problems comes on the solution is the net work ip address is not matched plz find and given correct ip address
Posted on Jun 15, 2009
While using checkpoint VPN-1 SecureClient to connect to Safe@Office 500 device in office mode, i can't connect to server at the office site. The office mode is on a different subnet than lan so my vpn...
In the rules, you will need to create a new rule that allows your VPN subnets access to you office LAN, and then on your office network gateway, add a route for your VPN subnet pointing back to your checkpoint firewall.
Nov 08, 2010 | Check Point Safe@Office 500 Router...
I am currently restricted to use of a wireless access point that requires cisco vpn. I have a machine running Win XP with a wireless card and a NIC card. I want to be able to bridge the connections from...
Your Cisco VPN client may or may not allow you to share the connectkion with other computers on your network. In Windows when you create a VPN connection you are able to go to the Avanced tab of the connection and place a check mark in "Allow other network users to connec through this computers internet connection"
Although you will need to bare in mind that the reason that the IT guy is not able to give you answer is because he has not idea what the wireless IP architecture is on the other end without you giving him this information. Also the most common error from poin to point on a VPN connection is IP conflicts from one network device on each side of the LAN. These types of conflict can take out the enire Campus depending on the level of security they have onsite.
Hope this helps
Sep 18, 2009 | Microsoft Windows XP Professional for PC
How to fix error 427
VPN error that says "secure VPN Connection Terminated by Peer. Reason 427: Unknown error occured at peer. " This error occur about 30 sec to 1 min after connection has been made. My users are not letting the system sit idle. What could be causing the problem I am using VPN Client 4.6.
Aug 06, 2009 | Computers & Internet
Error code 807 on printer display (not on computer)
  • The network connection between your computer and the VPN server was interrupted. This can be caused by a problem in the VPN transmission and is commonly the result of internet latency or simply that your VPN server has reached capacity.
    I know that the issue does not occur on other computers. Please let us know if all of the other computers are Windows XP computers, or Windows Vista computers are included. Also please let us know if the computers are in a same domain or network.
    I suggest that you temporary disable the anti-virus and firewall. Then, try to connect to the VPN again. If the issue persists, I suggest that you temporary bypass the router, and try to connect. If the issue does not occur, there are some settings on the router cause this issue.
mFor more help visit cbrtechsolutions
May 02, 2009 | Office Equipment & Supplies
Conflict with partner network detected.
Default password is "1234".
You need to set up a subnet that is different than the subnet your vpn is connecting to.
For instance, default on the 334is: 192.168.1.0/24 SO the router will have an IP of 192.168.1.1. Because of the error, the other network has that same subnet (192.168.1.0/24)
And that router probably has the same IP as your router (192.168.1.1)
So one of the networks needs to change. You could just change the IP on one Network to: 192.168.2.0/24 and the IP of the router to 192.168.2.1.
I would change them both though, so this doesnt happen again.
Apr 14, 2009 | Zyxel Prestige 334W Wireless Router...
Can't connect to AT&T VPN
as you told me that all the ports are open so in that case you can get in touch with your ISP and ask them to enable IPPASSTHROUGH on your office laptop.
Jan 17, 2009 | Zoom ComStar 56K 2818 Modem
VPN connection timed out
please tell me that who is your ISP at home?
Oct 25, 2008 | Trendware 54Mbps 802.11g Wireless AP
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Mar 04, 2008 | Trendware 54Mbps 802.11g Wireless AP
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Check Point VPN-1 Accelerator Card Cryptographic Accelerator Logo
180 people viewed this question
Top Check Point Computers & Internet Experts
DROPNDEAL
DROPNDEAL
Laxman Bisht
Laxman Bisht
Gil Shultz
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
