Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
Pressure switch light going off and heater won't start
I am having a pressure switch alarm on an lt400n-l heater
  • Gretchen Andrews
    Gretchen Andrews Mar 18, 2014
    I had this problem intermittently over a 3 year period and it was driving me crazy. I found I had two separate issues both having to do with wire connection that was preventing my flame to ignite. The first was actually in the Timer box. I found that I had corrosion build up on the ground connection that prevented the ignition. I fixed this by cleaning all connections in the timer box as well as taking the precaution that other connections could be building up the same corrosive issue, I cleaned all connections I could get at in the heater and attached securely. This seemed to have solved problem for several months but then again I had same pressure switch alarm return. This time I found that I had a break in the wire connected to the Flame Sense Rod. The wire was broke, but so little that it did not become completely separated. I was able to trouble shoot this by using a jump between the wire and the connector, this also served as temporary correction until I could order the replacement part. I recommend you take the rod completely out and clean it with an emery cloth to make sure it is also not corroded.
    Champion:
  • 305 Answers
Back wash filter. clean out pump basket, ensure you have proper water flow. Once you have ensure proper water flow and problem still exists, you will most likely have to replace the pressure switch
Posted on Mar 18, 2014
  • Steve Slater Apr 15, 2014
    You can put filter setting on "whirlpool", "bypass to pool", or "recirculate" (depending on filter brand). This will bypass water flow past the filter. If problem is resolved then the low flow issue is inside the filter.
  • Scott Corey-reid Apr 15, 2014
    if you put filter on recirc it bypasses the filter and wont clean the water wich is pointless. You have a faulty pressure switch, poor wiring, or you havntback washed filter in ages, or the sand in your filter needs to be changed, otur cartridge filter needsto be cleaned out
Laars pool heater wont start.
check safety circuit starting with pressure switch if voltage on both sides ok if not check pressure switch if ok check copper tubing it gets clogged at header
Mar 27, 2013 | Jandy Laars Lt 400,000 Btu Heater
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
LX400 low pressure switch
if good water flow through heater make sure if you have a bypass it is closed half way if not check pressure switch to see if 24 volts on both wires if not bad pressure switch or clogged copper line to it
Jan 02, 2012 | Teledyne Laars Laars Lx Pool Heater /...
Jandy lt400N L hi limit switch is showing. What can i do on my own to try and fix before calling service? Need details boys.....thanks :)
If you have a volt/ohm meter and you call Jandy technical support at 800-822-7933 number they may be help you resolve this issue.
Please let me know how this works out. Thank you.
Sep 02, 2011 | Jandy Laars Lt 400,000 Btu Heater
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
173 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
