Question about Whirlpool Duet GHW9150P Front Load Washer
Clothes get caught between tub and door
Clothes are getting caught between tub and door. This tears the clothes to pieces. Sears has been out twice, no luck fixing the problem.
    Problem Solver:
  • 14 Answers
Just wondering is there a small long panel at the front of this machine at the bottom if so should be a screw at each end ,take panel of im not sure but one of the sprung legs may have come off make sure machine is empty and look for the legs one iver side one might be lying down look at the other one and push leg back into its slot and slightly turn it,some of these machines flick the leg off if its been over loaded at some stage you might see if you look at the drum the front edge is dipping down,i know the one at woke the legs of the drum have come of 3 times over a number of years but they just slot back and its always fine after,hope this helps someone,ROY
Posted on Mar 18, 2014
  • Becky Hanson Mar 18, 2014
    We have not had this problem so I really don't have an answer. The problem we have is that little items like kids socks go under the rubber ring and do not get rinsed properly.
  • sampson_2461 Mar 18, 2014
    yes i know what your problem is ,but if the one leg is off then the drum will have a bigger gap between the door seal and the drum so items could get dragged between the 2
4 Suggested Answers
ngafm
  • 166 Answers
SOURCE: adjitater
Peace,
ngafm at your service!
STOP < DO NOT RUN WASHER!
Call service and don't run it any more!
you may cause more problems and cost more money!
Bless you,
please give me a good rating before you sign off
Posted on Sep 08, 2008
SOURCE: There is a piece of clothing stuck inside the tub,
you have to find one of two ways to remove the upper part of the machine.First, unplug the machine from the power source on the wall.By the upper part , I mean the lid of the drum. The first way is to check the back of the machine for a plate cover that is taller than the lid and cover of machine. If that plate is present then that plate has to be removed. If not , then go to the front of the machine and with a large flat head screw driver insert from the front on each corner and pry the lid up . you will see various styles of clips that hold the drum lid down and you will use the screw drivvito relase the lid . From there you should be able to remove the debris. To re-assemble simply drop the lid and re-secure the drum lid by pushing down on the front.
Posted on Apr 03, 2010
Jahn27
  • 1554 Answers
SOURCE: My whirlpool duet washer keeps
The problem is likely a result of overloading the machine. When the drum is too crowded, chances are, clothes are likely to gather at the front, get caught between the seal and the drum, and at high-speed spin, even a contact between the clothes and the seal can inflict damage. Other manufacturers like GE upgraded their door seals and provide it with a deflector that constantly deflects the clothes back into the drum.
The only thing you can do now to prevent the clothes from being caught and torn down is by making sure the machine is not overloaded. Also make sure the machine is level because when it is a bit sloping down to the front, the probability the clothes gather to the front and get caught is high. Replace the door seal if necessary.
Indicate the machine's exact model number if you require a more specific advice. You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice.
Posted on Jul 11, 2011
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Piece of clothing caught in spinning wheel
Hello, you a side load washing machine. The spinning wheel is a counter weight for the wash tub.
The tub out seal that fit around the tub is worn out. News a new seal. Unplug the washing machine and remove from cover with the door. Once you have the front panel with the door the tub seal is attached to the front by lock clips. Remove the clips or screws. Now, check the interior seal and make sure does have any hole in it. If there is holes then walter will leak on to the floor.
You might have to use a Laundry Mat for a few week while waiting for parts. GB...stewbison
Sep 10, 2011 | Washing Machines
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Articles of cothing get caught between the rotating drum and the frame--I'm sure these are not the correct structural terms. Too often, when I open the door, something will be caught and hanging, and I...
Your drum seal between the drum and the body of the dryer needs replacement, this is what causes the clothes to stick and tear holes in them.
I hope this helps
Please rate me
Aug 10, 2010 | Frigidaire Electric Dryer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Clothes get caught between frame and drum
Is this the dcvh515 GE? Mine began doing that and then started making a high pitched scraping noise that sounds like it's coming fron the door gasket/seal.
Dec 21, 2008 | Dryers
Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
Clothes getting caught on inside of dryer
There are a couple of guide wheels in the back of the dryer. when they get worn out the tub will have excessive play and will trap clothes inside. Just remove the front cover loosen the belt and remove the drum. the worn wheels will be easy to spot. It is an easy and cheap fix.
Nov 02, 2007 | Kenmore 98702 Stacked Washer/Dryer
Fridgidaire Front Load Washer
This is usually an indication that the rear tub bearing is starting to go bad. The bearing is located in the rear shell of the wash tub and cannot be replaced. In order to repair, you would have to replace the entire rear shell because the bearing is actually molded into the plastic. This is common with front loader washing machines. Another possibility could be items getting caught in the rubber door boot and leaving rubber marks. However, normally this will be associated with a leak somewhere. Inspect the entire door boot and clean in behind the rubber. Inspect for any rips, tears, or places where clothes can get caught. I have experienced clothing getting snagged and actually pulling the door boot off. If the marks continue to show up on your clothes (they may even turn a brownish color) I would look into an estimate on how much it would cost to have the tub bearing replaced. It is not an easy repair, and it is not cheap. The cost usually runs around $500. I hope this helps.
Aug 08, 2007 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
