Question about Pyle PLTS77DU Car DVD Player
NO VIDEO SIGNAL
I HAVE NO TYPE OF VIDEO SIGNAL
I want to isolate where I can introduce a video signal and monitor it
If it is a desktop (tower) the video signal from the computer goes into a cable which is connected to the monitor. There are two types, one being a VGA type, the other being a digital type. Look these up on Google, images, to find which type you have. If it is a laptop, there may be a connection for an external monitor, usually a VGA plug.
Sep 28, 2015 | Computers & Internet
Video is reporting No Signal
check the menu for proper video input signal type.
or system , like AUTO, PAL or NTSC
Mar 02, 2013 | Eiki LC-X50M Projector
My Sharp LC-32SB24U says An incompatiable video signal has been recieved. Check the output device settings?
It sounds like an HDMI lead has standard video on it or the output from a digital unit is not the correct specification for your TV.
Check the instruction booklet for recomended signal sources and then check your DVD, Video, Computer for the right type of signals to be outputed to your TV.
Hope this helps.
Oct 29, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Input not supported message appears when I hook the monitor to my dell computer.
This could be many things:
A. Your monitor is capable of receiving more than one kind of video signal - like a TV - and you need to change the input source (see manual).
B. Your computers video card is capable of outputting more than one type of video signal, and needs to be set for your monitor (Control Panels).
C. You are plugging the monitor into the wrong video port.
Apr 25, 2010 | Compaq Computers & Internet
Rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Feb 14, 2010 | Yamaha RX-V1900 Receiver
No video signal. What type of video card should I
First check the connection cable to the monitor from the CPU
Sep 28, 2009 | Gateway GT4023E (6886) PC Desktop
S-video problem on Panasonic TV
Have you tried another S-Video patch-cord?
Some cheaper ones short across pins.
What output from DVD are you using?
If composite video 'Yellow' RCA socket, a cheapo cable can also create sync problems ie signal timing, causing patterns on screen.
The S-Video is actually 2 signals - one for Chroma C and the other for Luminosity Y. With S-Video to S-Video connections, this gives better quality than composite, as each line can handle separate voltages, levels and frequency for Chroma = pixel color and luminosity = pixel intensity.
Composite has to cram all this info onto one channel, so signal quality is lower than S-video.
A hack that videophiles use is to place a 470nF ceramic capacitor across the 2 signal pins, instead of the cheaper just bridging them together.
This apparently helps to re-sync the combined signal from composite.
A tester on ohms and steady hands can test whether your cable is cheap-shorted type, or better synced type.
Across C and Y pins:
0 ohms=shorted
high reading or open=small sync cap
If making own cable mod:
Pins are closely spaced, so easier way is to strip and dress cable near S-Video plug, solder wires to cap accordingly, join composite to cap & Gnd as shown, insulate.
Nov 20, 2017 | Panasonic CT-36D31 36" TV
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Joe
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting 5 plasma tv as media network
Questions, Where would the source signal come from ( a single DVD player)? So far I gathered that "one" signal will feed into 5 different screens?
Nov 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Power on but not busting [no eht]
It measns that there is not video signal whether it is from any type of DVD player or any type of sat top box.Try to check signal cables.
Oct 24, 2006 | Philips 42FD9954 42 in. Plasma HDTV
Pyle PLTS77DU Car DVD Player Logo
42 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
